Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
I just bought new batteries for my Pride Ultra Go Go, but can't get them to start charging when I plug the charger directly into the outlet. Help please.
  • 14 Answers
1.Make sure you installed them correctly.
2.Check the voltage on the batteries. If either (or both) register less than 11 volts, either return them for ones that have 12 volts, or attempt to bring them up to 12 volts with an automobile battery charger. Once brought up to 12 volts, install them, then make sure you recharge them with the supplied charger/adapter before or when the on-board indicator it shows low (red). If the battery voltage drops too low, the supplied charger simply won't even try to charge them.
Posted on Aug 20, 2010
Pride Jet 3 Ultra 4500 rpm, unit is completely dead, am I missing an auxiliary charger or is it built into the unit?
I suggest that you start with determining the condition of your batteries and work outwards from there. Dead batteries just don't want to take a charge. Test your batteries with a meter before you start part swapping. The internal charger is only about 4 amps so it will take many hours to charge a 24volt system.
May 06, 2013 | Jet 3 Ultra Power Chair
I have a Jazzy 1113 ATS .The batteries are bad .I charged them individily on a different charger .I plugged the onboard charger in but do not get a voltage reading on the plug to the batteries .
huntin you might not get a reading at the plug to the batteries because if its not connected to a load the charger might operate until it senses a load. a better way to check would be to plug the charger into the outlet and take your meter set it to 200 volts dc and plug it into the two outter holes of the chager port located under the front of the joystick. you should get 27-30 volts dc with the charger plugged in. when you unplug the charger you will be reading the battery voltage. After charging overnite you should be reading 26-30 volts dc if you aren't getting that voltage replace the batteries Hope this helps
Mar 24, 2011 | Pride Mobility Products New Pride Mobility...
New batteries won't charge on Jet3 Pride Chair. I've pushed the reset button and have voltage from the receptacle. Thanks if you can help!!
Lets make sure the all battery terminals have the correct cable ,heres a web sit that you can go on to double check.http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_Ultra_om.pdf
Page 40 shows a diagram that covers it all.
Next after confirming that everything is connected correct,plug the chair in like if you where going to charge it,
I want you to check your ammeter if the needle moves to the center of the gage your charging if not you may have a bad charger.
Good luck hope i was helpful
Jan 24, 2011 | Pride Mobility Products New Pride Mobility...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Charging light wont come on, this is my first time charging scooter
make sure the outlet your using to plug in the charger is good (plug in a lamp,light or radio to check) if good make sure the charging cord is plugged in all the way. If you using an extention cord, try without.
Jul 12, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
May 29, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
New battaeries willnot hold charge
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
Jan 13, 2009 | Pride Mobility Products Pride Mobility...
Scooter is dead
Are you sure your charger is working? Is the free-wheel lever engaged? Also the charger has an inhibit line, it will not run when the charger is plugged in.
Nov 16, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
380 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
