Question about Whirlpool MH3185XPS Microwave Oven
How do I replace the door handel - Whirlpool MH3185XPS Microwave Oven
    President:
  • 1,565 Answers
Http://www.fixya.com/support/t826280-door_handle
I will be doing this repair myself in the near future
Posted on Sep 05, 2010
  • cheap repair Sep 09, 2010
    move slowly when removing the plastic around the glass. You will want to scream when taking it off as it does not come off very easily. use a thin, narrow metal scraper to undo the plastic latching fingers. the fingers are not on the glass edge side; they are on the outer edge. You really don't have to take the door off to do the repair. In fact getting it back together correctly is near impossible if you take off the door. The brittle plastic can break easily.
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 12, 2014 | GE Microwave Ovens
Replace door handel
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 16, 2012 | Whirlpool MH7130XE Microwave Oven
Wmh3205xvs door handel
see the video and fix it. God bless you.
Nov 15, 2012 | Whirlpool WMH3205XVS Stainless Steel 1000...
How to replace door handle
open door
lift up seal of door to expose srews then remove
sperate seal and inside door glass
that exposes screws for the handel remove and replace
Jun 30, 2012 | GE JVM1330BW/WW Microwave Oven
To make oven go on you have to hold the handel up
That would be a bad bottom door switch or that switch's mount. See this helpful text file.
We have the service manual and have uploaded it to our site here to help you.
You can find helpful exploded view diagrams and order other parts by entering your model number at the Pros' site here.
Jan 11, 2011 | Frigidaire FMV156DC Microwave Oven
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
I hope this helps you
a
Sep 22, 2009 | Jenn-Air JMV8208A Microwave Oven
I oderered, & received a new handel, to replace the broken one.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info and step by step help in disassembly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 25, 2009 | GE Advantium 120 Convection/Microwave Oven
Smh7187sgt samsung microwave handel replacement,how to get to the screws
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 24, 2008 | Samsung SMH7178STD Microwave Oven
Replace door handel
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Dec 04, 2007 | GE JVM1660 Microwave Oven
Whirlpool MH3185XPS Microwave Oven Logo
113 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
