Question about HP Photosmart 3210 Printer
My HP 3210 all-in-one printer does not power up when I plug it in. It appears to be getting power because when I plug the printer in, the little bluetooth light in the front lower right does light up. However, when the power button is pressed nothing happens.
    Problem Solver:
  • 4 Answers
Are you taking it off electricity a log? If so you have to set it up to your preferences sometimes. And are you tapping the "on" button at far left at the top? It should work. But it must be plugged in of course and the button has to be pushed. Don't push too hard or too long or it will turn off.
Posted on Aug 13, 2010
My 3210 shows Ink System Failure error what does that mean and how do I fix it?
hi there
we have one printer like that in our company and the problem is the same ink failure system i tried to check and clean the ink line but the problem is still the same, i try to bring it in hp service center and it is fixed but it willcharged you little bit high. try to unplug all the power from theprinter and also in the wall outklet and wait for sometime and plug it again. if the problem is still the same my advised is consult hp service center.
thanks
Apr 23, 2011 | HP Photosmart 3210 Printer
0xc18a0401 appears on the screen after start up of the printer When trying to copie : same fault. Can you give me some advise.
Try resetting the printer. With the unit on, unplug the data cable (USB) from the back of the printer. (At times, unplugging the data cable from the computer helps). Then remove all of the ink cartridges and wait for the message "Insert Ink Cartridges" to appear. At this point, unplug the power cord from the back of the printer. Wait 60 seconds (or longer) then plug the power cord back in. Power on the printer if it doesn't come back on. Reinstall the ink cartridges when the unit prompts you to do so. Close the cover. Print a calibration page if you get a prompt to do so. (Do the complete calibration including scanning the calibration page.) Finally plug in the data cable (to both the printer and the computer if you completely disconnected it). .
Try printing again.
If the error persists, the unit needs service from HP. You will need to decide if the cost is worthwhile if the printer is out of warranty.
I hope this helps.
Dec 02, 2010 | HP Photosmart 3210 Printer
When I am printer Hp 3210 Messe error like this 0xc18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jun 07, 2010 | HP Photosmart 3210 Printer
Hp photosmart 3210 error oxc18a0206
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 12, 2010 | HP Photosmart 3210 Printer
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
No Power
Usually there is no fuse in the printer itself. The big block that you plug into the wall is actually a transformer. It converts the 120V power from the wall outlet to a much lower voltage and also converts it to DC power.take the plug in end with the cube transformer in it and bring under a good light and it will read the specifications about that power converter. What sometimes happens is that the transformer inside that cube fails (through various causes) and thus produces no voltage or the wrong voltage. Take the plug with you to an electronics store of your choice and they will direct you to a universal 120AC to a DC transformer (it will have various settings and various plug adapters) and then follow the instructions to match the voltage on the old power converter. I hope this helps you out.
Jun 04, 2009 | HP Photosmart 3210 Printer
Is there a reset switch on the HP Photosmart 3210 printer?
Unplug the printer, check all cable connections, and plug it back in. If it still doesn't work, your power may have surged and killed the power supply or other components in the printer. If this is the case, you are best off buying a new one, as you'll spend more in parts and labor then a new one will cost.
If it is still under warranty, I'd try and redeem that.
Mar 25, 2009 | HP Photosmart 3210 Printer
HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP All-in-One 3210 Carriage Jam
e cycle for sure ... unless the little plastic part was off tha cartridge
Apr 10, 2008 | HP Photosmart 3210 Printer
I have a Ink System Failure.
I had this same problem but with a different error code. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Mar 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
