Samsung WF203ANW Front Load Washer Logo
Posted on Apr 27, 2008
Samsung washing machine J1453. Error code 4E constantly recurring despite checking of water supply pressure and pipes/filters. Any suggestions?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7250
Points
13
Had a same fault code and also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
  • dbscrumpy Aug 22, 2011
    Thanks everyone. Even after three years, this was EXACTLY the problem that we had. I followed the instructions and it worked!!
    Thanks Bumpit
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1444
Points
Thanks Bumpit. After reading your post I opened by j1453 and immediately saw the problem you described. Fix it!
Peter
A
Anonymous
Bumpit has it sussed followed his advice. it was a split at the sensor end of the pipe very tiny. cut it off stuck it back on and no more problems
Samsung 4E Error. I have a Samsung washing machine that will not finish the wash cycle.
The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
Aug 23, 2021
How to resolve 4E or 5E codes on your Samsung Washing ...
https://www.samsung.com > ... > Home Appliance
About featured snippets
Feedback
People also ask
How do I fix E4 on my washing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> What does E4 mean on a washing machine?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;"> Feedback
How to resolve a 4E or 4C error code on a washing machine
A problem with the water supply is usually the result of low water pressure or a low flow rate on the mains water supply to the machine. This means that the ...
Samsung United Kingdom · ‎How to clean the detergent...
2answers
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
Have samsung sw5ousp 5kg it is showing 4e water error any help b great thanx in advance
The Error indicates that the water level did not increase or fill in time to the machines estimation . 4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
E4 mean
The Samsung washer error code reads 4E and means problem with the water supply. Please check the water pressure, also check for blocked or kinked water supply hose. You can learn more about all Samsung washing machine error codes in this helpful article: https://www.justfixed.co.uk/samsung-washing-machine-error-codes/
Hope this is helpful and good luck!
Best,
Dave, Just Fixed
2answers
Samsung Washing machine fault
The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
