Question about Nintendo Wii Console
I keep getting a error code 51330 what am I doing wrong
    Genius:
  • 1,234 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
SOURCE: Setting up wii wireless
log on to the router and get the right wireless key if the router has multiple solts to enter wifi key select to 1 if the above is right its its to do with mac filterting if the mac filtering is enable u must add wii mac address to allowed list if the mac filter is disabled no probs try changing the channel set to 11  set the wireless to mixed or b/g mode try manul set up of wii try turning off the router and wii  then confuguring again hope this will fixya
Posted on Nov 02, 2008
saif123
  • 104 Answers
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
Posted on Jul 22, 2009
  • 20 Answers
SOURCE: I am trying to connect my Wii to my wireless
adhora5
Posted on Jan 06, 2010
eddiepeezy
  • 130 Answers
SOURCE: error code 51330
That's usually a problem related to wireless security. You'll want to try to make sure your computers can connect to the wireless--or see if it's working or not.
If everything is good. Make sure the password you have on your Wii to connect your console to the wifi is good.
That should work... if not, reset your wifi settings and try again!
Posted on Feb 08, 2010
Posted on Apr 26, 2010
I keep getting error code 51330
Hi.
This Error Code: 51330 has something to do with your wireless connection.
Please click on the link below for steps on how to resolve the problem >>>>
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Good luck.
Sep 05, 2011 | Nintendo Wii Console
Can't get on netflix error code 51330 keeps coming up
This error message indicates that you are entering the incorrect router security key in your Wii network settings. This security key allows your Wii to gain access to and use the internet through your router. I wrote a tech article which goes over how to resolve 51330 errors. You can click here to read it.
-G33k
Aug 07, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
Trying to connect to wifi and keep getting error code 51330
i had the same problem when i set up my wii, your wireless settings have changed, you need to find the password, i thought i knew it but i was putting the wrong one in, you have to make sure you are putting the current password in
Jan 30, 2011 | Nintendo Wii Console
I can't connect to the internet via my router
i have bought a dlink wireless router.hooked up to desktop computer ;with no problem. but can;t get a signal for my laptop (toshibs 2000 professional) can you help me what am i doing wrong ;do i need to buy something for the laptop.
Jun 07, 2009 | Dell Wireless 2350 Router
Can't connect Wii. WEP key is correct.
either your internet provider does not support the wii or vice versa. another possible problem is that you have the WEP strength set wrong. IE: having 64 bit and treating it as 128 bit.
Mar 16, 2009 | Video Game Consoles & Games
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
