Question about Sony Cyber-shot DSC-W50 Digital Camera
Not focusing, picture is blurry, lens goes in and out, tells me to turn on and off
  • 455 Answers
This seems to happen when the Lens unit in the Camera is stuck and not retracting. The possible troubleshooting steps to resolve this issue are power resetting and factory resetting.
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset:(This can be performed only if the Menu of the Camera is accessible)
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
Home-->Settings-->Setup 1-->Initialize-->OK
Posted on Aug 07, 2010
5 Suggested Answers
Nickstar19
  • 417 Answers
SOURCE: Lens keeps moving in and out, plus, the screen is blurry
FAULTY OR ITS NOT WEATHER PROOF
Posted on Jul 03, 2008
Agent Allan
  • 480 Answers
SOURCE: lens
Hey ajvg,
What is most likely happening is there is something obstructing the movement of the lens (i.e. sand). If this is the problem you could try blowing compressed air from canned air into the side of the lens to try and dislodge whatever is obstructing the movement of the lens. If this doesn't work you could try putting the camera on a flat surface with the lens pointed up while holding the shutter button in press the power button. This will sometimes help if something is out of alignment inside the lens. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 16, 2008
jimmyneutron
  • 14 Answers
SOURCE: camera will not take clear photos
As you have noted the lens is the root cause of this noise problem. I really believe there is grit in the lens gear thats preventing it from zooming or re-tracing. As for the blurring this can happen due to shutter lag.. a notorious problem in some of the powershot models. Either ways your camera needs service by an authorized professional. I would not advise you to try and clean the lens gear yourself as it can very easily get messed up and it would significantly rise the cost of the repair.
Good luck
Sai.
Posted on Feb 03, 2009
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
Posted on Jun 02, 2010
I cannot get my lens to focus. Can anyone give me some advice or tell me what could be wrong with it?
Are the pictures sharp? If so, the problem isn't the lens, it's the eyepiece. Most have a small dial to adjust the focus of the viewing system. Try adjusting that. . .
May 25, 2015 | Cameras
Dslr camera
What make and model camera? Which Sigma lens? Do you have autofocus turned on, both on the camera and the lens?
Jul 01, 2013 | Sigma Cameras
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
Have a canon digital elph sd750. Pictures are now blurry.
You could have cracked the lens, damage the focus or a number of other things but the lens and focus are most likely. check your lens for scratches if there is none and no cracks take it to your nearest camera store or buy new good luck!
Aug 08, 2009 | Canon PowerShot A75 Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2009 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
Everytime I take a picture it turns out blurry
Inside the lens their is a focus motor that has to be perfectly set if it get out of ajustment this will cause a blurry image it you try to zoom some times you may get a lens error this is because the lens has been obstructed from the inside by the focus lens. the lens eather needs to be replaced or rebuilt.you may find a broke one off ebay with a good lens pretty cheap if you are going to try and repair it your self.
Mar 20, 2008 | Mercury Electronics CyberPix S-555V...
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony Cyber-shot DSC-W50 Digital Camera Logo
361 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
