Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Replaced coil motor starts and runs at an idle and at high rpms as soon as you start the mower blades the governor opens wide open and black smoke comes out the exhaust. seems like its choking out and the motor won't pull itself. 20 hp intek v twin
  • 21 Answers
Could be air cleaner clogged and/or crankcase ventilation
breather or tube to air cleaner frame work clogged
Posted on Sep 26, 2010
SUBARU EX21 GAS ENGINE RUNS WIDE OPEN WILL NOT IDLE
adjust jet to full close then open quarter turn , check manifold for leaks .sounds like the gasket leaking not tight ,
Apr 08, 2014 | Garden
Revs to high
The throttle plate is spring loaded to pull wide open, opposed by the governor which will pull the throttle closer to closed when the limited or specified rpms are reached. If the governor arm does is not connected to the throttle bell crank(linkage broken, off, or missing), it can't pull the throttle closed. If the arm does not move to close the throttle, the governor is likely broken inside the crankcase. or needs adjustment. The internals are a spool that moves based on rpm, pulled up by flyweights that has the external governor arm shaft 'trapped' in between the spool 'ends'. The spool will move the shaft and in turning, move the arm to pull the throttle closed. You adjust the arm on the shaft so the governor can pull the throttle completely closed with all the slack taken up.
Mar 14, 2014 | Garden
Adjust governor
this one have to see. but make sure the spring are all there on the governor. good fuel line and oil levels not to high
Oct 11, 2013 | Craftsman Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Will not idle
Reconnect the governor rod back on to the carby throttle butterfly correctly. When stopped the lever will hold the throttle wide open and as it starts the lever pushes /pulls the throttle closed to the idle stop screw
May 31, 2013 | 5.5 HP GX160 Engine
Briggs and stratton mower will start but will not run and when it does run it is very high idle
lots of things it could be........check the obvious first
1.....throttle butterfly to see if it had come out of the carburetor
2.....check static governor settings. to set rotate carb to wide open throttle, loosen governor arm and rotate it to the right, tighten jam nut, if it still runs away then you have a blown governor inside the mower
3..... check for unhooked springs and linkages
hope this helps and good luck the above 3 things to check is 90 percent of all my repairs in the shop when it comes to the engine running too fast
see ya!
Nov 23, 2009 | Briggs & Stratton Garden
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Jul 14, 2009 | Mtd 22" Yard Machine Push Mower
I have a craftsman 18.5 hp, 42 inch mower that died the other day while idling. When I cranked it, now it runs wide open and the throttle has no control. "mcolvin@cei.net"
if you start the engine and there is no control on the engine...the governor is broken/damaged and must be replaced
Jun 29, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
428 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
