Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
The on and off switch needs to really be pushed hard to get the computer to turn on. It can take many trys to get it running. Can I get a replacement switch and can I do it myself?
    President:
  • 2,571 Answers
Its usually just a little coil spring on a post behind the button.
Take the sides off the case, you should be able to see the clips needed to release the case front.
You may just be able to stretch the spring.
If this is not the problem there maybe something snapped
Posted on Aug 06, 2010
Testimonial: "This sounds simple to do, thank you "
LCD TV DELL 2600 remote does not work until tv is turn on, also tv is very hard to turn on with manual button.
hi,hard to push bottons on TV manual controls usually happens because they are not use for a long time carbon accumulates inside the switches.You can just use a contact cleaner spray (windex) just spay it directly to the button and press repeatedly until dry..good luck1
Apr 07, 2012 | Dell W2600 26 in. LCD Television
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
COMPUTER WILL NOT STARTUP
there is a bad piece of hardware( could be the video card) you really should check it with a POST diagnostic card
Sep 15, 2009 | Gateway (4000811) Motherboard
Dryer drum won't start unless I manually push start the drum,  then it'll run fine. Turning the start knob just sounds like it want's to start. So right now I have to hold the start button, hold the...
unfortunatly it is either the motor or the drum bearings in the machine. if it is really hard to push i would suggest looking at all the bearings the drum rides on otherwise it is probably the motor that is getting weak.
Jun 08, 2009 | KitchenAid KEYS700LQ Electric Dryer
Computer turn on and Restart Problem.
Are you pushing on the hard disk?
this is a hard disk, are you pushing on the hard disc or on the case of the computer? if your pushing on the case of the computer then most likely the power or reset switch is loose or broken.
do you get a blue screen or what happens? are you really pushing on the hard disk? if your really pushing on the hard disc I would suggest to replace the hard disc to one that doesn't need to be pushed and works properly,
Apr 27, 2009 | ATI RADEON 7500 (64 MB) PCI Graphic Card
PowerPC G4 switch-on problem
Hi Branko
Rather than forking money out for a battery. There are a couple of things I really need to know first. Have you changed anything on the machine recently? What OS are you running. How much memory (ram) Size of hard drive.
As you are running quite an old mac these details are important to identify the problem.
Paul
Nov 18, 2008 | Apple Power Mac G5 Desktop
Dell 610initial start up problem
Hi!
You are unable to enter bios....to select drive c...try to remove the hard drive and install it in the other machine that you have....or just boot your notebook without the Hard disk and see if it makes any difference.....
Can you explain more on...
"The computer trys to start and then just shuts down in approx, 8 seconds."
Nov 13, 2008 | Dell Latitude C610 Notebook
Philps LCD Monitor Won't turn on Straight away
That is definitely a problem with the monitor...if its under warranty have it replaced...if not...start looking for a replacement it hardly ever is worth it to have them repaired (shipping, parts, labor is usually a little less than a new monitor). Sorry
Aug 28, 2007 | Gateway FPD2275W LCD Monitor
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
98 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
