Question about Hoover Vacuums
I have an old Decade 80 Hoover vacuum that works great but the headlight bulbs are burnt out how do I get at them to replace? I'm afraid if I try to pry the lens off it may break.
SOURCE: My 2month old hoover bagless stopped working completely!
I may have figured out a way to make this thing work. If you find that the problem is the flimsy, floppy piece of plastic that I mentioned above, I think that the thing to do is figure out a way to make the narrow sticking out fin-like section that activates the switch wider. I think what happens is that fin slips over to one side or another and then does flip the switch. What I just did is cut a hard rubber washer into two half circles (or approximate half circles) and attached those on each side of that fin. So now I have a nice wide switch activator. I attached the pieces with exterior mounting tape. I imagine that some sort of adhesive could be used too, as long as it is not something that would dissolve the plastic.
Posted on Apr 08, 2007
Buffalo12980
  • 625 Answers
SOURCE: HOOVER VACUUMS
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Posted on Sep 22, 2007
SOURCE: replacing vacuum belt
thanks for your concern...........a friend of mine said you very carefully have to pry the top off and you can get to the belt.............it worked and i didn't break anything.........it now works fine............thank you again.
Posted on May 23, 2008
  • 61 Answers
SOURCE: The headlight on my Kirby doesn't work!
A few problems exist in this situation.
A. Is the bulb you put in a genuine kirby part?
If not it is probally not the correct anperage.
B. Are the little medal pieces on the end lined up correctly? If not adjust and retry.
C. The socket the bulb fits into is bad. In that case call 1-800-948-1358 mon.-fri. 9am-6pm est
sat.9am-2pm est and ask for josh or buck to order the socket.
Posted on Apr 16, 2009
VacuumRepair
  • 438 Answers
SOURCE: Hoover SteamVac brushes aren't turning ...
Sometimes this speed knob can be really stuck on there. Even if you were to break off the part that the knob sits onto, this part is actually part of the turbine assembly, and the new turbine assembly would have that prong that the button sits on.
As long as you have the screwdriver underneath of the knob, I wouldn't worry to much about putting too much pressure on it.
Let me know if you still have any questions, I'll be happy to help you figure it out.
If you found this helpful, please be so kind to rate the repair that I wrote, or leave feedback.
Thank you,
Chris Jones
GoVacuum.com
Posted on May 28, 2010
Testimonial: "I appreciate the helpful advice and feedback."
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Machine wont turn on
Either the motor is fried or the belt is burnt. If you can't hear it turn on, then check for any fuses that could have blown. They will be glass tube type. If fuse is good, motor or power supply could be bad. You can test them with voltmeter.
Sep 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover carpet cleaner is approx. 7 yrs. old....husband believes motor is shot? Smells burnt when running....fix or buy new???
you are correct, the motor is shot. if you like the machine replace the motor. i would get an est. on the machine from your local vac shop and the go price them. in some cases its better just to get another machine.
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Apr 16, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Hoover tempo
sounds like a blockage or belt off in the foot of the vacuum. there is no reset button on this model.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Roller
is the headlight working,if not there is a circuit board inside the base that is probably burned up.i have the same thing now i need to find the circuit board
Oct 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
152 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
