Question about Smeg Ovens
I need a manual for an smeg sa990xr oven. any suggestions?
3 Suggested Answers
  • 86 Answers
SOURCE: NEED USER MANUAL FOR SMEG SE375MFX5
SMEG SE-375MFX5 Owner Manual
Posted on Feb 09, 2009
diodeic
  • 1622 Answers
SOURCE: My Smeg oven model: SA990XR has
All you can do is to open the oven to check for blown fuses, if found replace with the exact rating of the fuse,There is a ceramic fuse located somewhere behind the control panel, usually toward the bottom of the case. It's likely bad. Find it, remove it.
f the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Hope this will help in solving the problem, take care...
Posted on Sep 16, 2010
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Sep 08, 2012 | Smeg Ovens
Do you have a softcopy manual for SMEG SE210X/1 Oven
Well you may please follow the link below to get your manual -
http://safemanuals.com/user-guide-instructions-owner-manual/SMEG/SE210X-1-_E
Good Luck!!
Thanks for using FixYa!!
Mar 27, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Smeg se398x/1 user manual
Please download your manual at : http://www.devicemanuals.com/guide/Oven/SMEG/SMEG-SE398X-1-Oven-Instruction-Manual-Spanish-==TWpFNU5qUXo=.html
Regards
Dec 15, 2010 | Ovens
Need a copy of manual
try smeg.com/manual
It came up for me ,see if your item is on there.
Feb 05, 2009 | Smeg DO81CSS Electric Double Oven
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Ovens Logo
93 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
