Question about Bushnell Sportsman 3-9X32 Silver Gun Scope 721393S
How do i calibrate the scope to hit where im aming the crosshairs?
  • 2,100 Answers
Bolt action? If not, ignore this, but , if it is a bolt gun, remove the bolt. Mount the rifle in a vice type clamp or a cardboard box with v's cut in it to hold the rifle steady, aim through the bore at a target 100 yards away. make the rifle stay on the target, now peek through the scope, it should be on the same target, if it isn't, move the adj up or down, left or right to get it on target, then check the bore again, then the scope again. This will put you on paper at 100 yards, fine tune it from there. Hope this helps.
Posted on Aug 09, 2010
Can adjust scope low enough
Hey Andy..
The scope won't adjust "lower".. lets talk about what you are calling "lower". The "lower" the "crosshairs" go, the higher the gun shoots...and to the opposite end...the "higher" the "crosshairs", the lower the gun shoots...
If the barrel and the scope are perfectly parallel.. when you lower the crosshairs in the front of the scope, the barrel will/must be raised to hit the same spot.. and the opposite is true for the other direction...
......IF this is what your are experiencing,, no biggie..
If this situation above is NOT what you are experiencing, the scope mounts need to be "adjusted" or replaced..
Sep 25, 2017 | Optics
What are the marks below the crosshairs
They are used to indicate elevation needed to hit your target at various ranges. The distances should be indicated in your owner's manual. For instance, if calibrated for .223 remington, and sighted in at 100 yards, the first might be 200 yards, the 2nd 300 yards, etc.
Dec 01, 2013 | NcStar 3-12x50e Rifle Scope Illuminated...
Crosshairs moved after rifle was sighted in
now then,,,did the crosshairs move or did the scope slip back out of line? if the mounts were not tight then its likley to be the scope slipping back but if the crosshairs moved were they just setteling or are they moving,,if there realy moving the scope is claped out or shook apart inside,,,how big is your rifle you put this scope on? 357mag??? i have a simmons scope on a 7.62 and on a .303 enfield rifle its ok on them?
Nov 02, 2009 | Simmons Optics
How to use accutrac 2x7 redfeild scope , there are lines above the crosshairs and a yardage graph on the bottom of the crosshairs, how exactly do i use this scope
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Oct 07, 2009 | Redfield Optics
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
Simmons scope that will not stay on target
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
NEED REPLACEMENT PART FOR TASCO 4X15 I NEED THE CROSSHAIR PIECE
im sorry but the price of that scope is not worth getting new crosshairs, you should just go get a new scope at walmart. they are like 9 bucks. But i myself would get a better scope, you can get decent ones for liek 60 bucks. Last a lifetime if you take care of them. The best scopes can cost 800 dollars on up. Just get a new scope. the part would coast more then the scope.
Dec 13, 2008 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Bushnell Sportsman 3-9X32 Silver Gun Scope 721393S Logo
215 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
