Question about Motorola Mobility CLIQ Cell Phone
Touch screen does not work when in the open position e.g. actual keyboard visible and when its closed and using the android keyboard it responds slowly and or enters incorrect keys
  • 677 Answers
Hi, You need to check the flex,
FLEX
Hi,what makes the phone to display phone half of it is white with this big black dot to the side of it,
is because there is a flex inside that connected to the screen of the phone that makes the phone display
is faulty and it needs to be replaced so that the screen can be as one again.
Touch screen
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care.
Posted on Aug 06, 2010
  • Ccrae88 Sep 14, 2010
    where do you get a flexi from?
Having a problem with the touch screen with my Roland E80 keyboard work station. Very slow or no change . Please help .
Open up the Roland E-80 and check if all connectors and flatcables are well seated.
Dec 21, 2016 | Roland Music
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
Can i connect a mouse to my tablet if the touchscreen is damange
you have cracked the touch part , easy to replace . youll need nerves an a ebay account to find parts for it, it might take you time. you can pair a keyboard to it or install remote access if the touch worked . too late now u need parts.
Jun 26, 2014 | Android 7-inch Touchtab Mid 2.2 Tablet Pc...
Huawei m866 touch screen stuck on android touch doesnt work
MOBILE PHONE TYPE> HAUWEI M886 ANDROID SMART PHONE
SITUATION > TOUCH SCREEN NOT RESPONDING I CANNOT PROVIDE MAINTENANCE TO MOBLE PHONE... IT TURNS ON BUT CANNOT MAKE SELECTIONS
Jan 22, 2013 | Huawei M886 Mercury - 4GB - Black Cricket...
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Phone went dead and now the touch screen wont work. i cant put my access pin in through the keyboard so it wont open. What do I do?
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 28, 2010 | Cell Phones
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Samsung F700V shortcut display problems
Hm, this is a difficult one. I have a F700 and there is no option for it to auto lock on slide closure. U might have a different firmware so look around the settings for it. Disable it if you can find it.
This might also sound stupid but make sure the lock key on the right hand side has been slid up. Slid down locks touchscreen.
My f700 does NOT launch the camera upon pressing the camera button at home screen. It does nothing if i do that. I need to goto into the menu and then the camera for the camera button to work and to take pictures. I think this was a smart move for Samsung to design it like this. I could see myself accidently pressing that many times.
Jun 23, 2008 | Samsung Ultra Smart F700
Motorola Mobility CLIQ Cell Phone Logo
311 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
