Question about Toshiba 2860 Copier
Light copies why coipies getting light?
Prob because its low on toner-----I'm not even a tech but that would seem to the obvious answer
Posted on Apr 28, 2008
Copy is light when i started copying in the morning.
This is Relates to your developer unit, you have to change it, the reason why it work when you run mode 130, is because you adding toner on the developer, and when the developer gets empty, it gets lighter and you have to force it again by adding toner with mode 130.
Nov 09, 2011 | Kyocera TASKalfa 180 Copier
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
When trying to scan or reprint a picture on my HP photosmart C5180, and I choose a 4x6 or 5x7 or8x10, it prints out a thumbnail picture. If I insert my card from my camera, it prints a beautiful 4x6 print....
please go ahead and right click on the printer icon and ytou will get an option that says printing preferences
fromthe printing prefercnces select photo printing select the right photo printing
select the size and the printing type
hope this should fix the problem for more details you can also foillow the instructions from hp
since the ocpy is not fine you can try and do these steps:
1.disconnect the power cable from the back of the printer
2.press and hold the power button of the printer for 20-30 seconds
3.restart the printer and see if it coipies fine
for more details please download the manual from te following URL ;
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=1153481&lc=en&cc=us&dlc=en&lang=en&cc=us
thanks
regards
Hamid
Feb 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do you send a group mailing?
Firstly creat a group from NEW''
Then add all the recipients into the group with email address
When you want to send mail call up the group name say musicgroup or whatever you named it and write the content into it and just send. it will send a coipy to all members in that group
Please rate my help++++Thanks for usding FIXYA
Nov 20, 2009 | Yahoo Mail
Why do my copies come out so light?
I found that I had to adjust the settings or my copies were almost illegible. Instead of copying at greyscale or black & white, try setting for color copies (even if using a black & white laser printer) and 600 dpi. It takes a few seconds longer to scan, but you get very clear copies that way.
May 01, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Can I recover my photos...the battery run out as they were .....
Try some photo recovery software to rescue the files on your digital camera memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Feb 17, 2009 | Fuji FinePix Z10fd Digital Camera
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Light copies
If you have changed all you mentioned with the correct parts, I can only advice you to change the control board.
Try to warm your papers
The same power you are using now, is it the same you have been using before facing this light copy problem?
May 08, 2008 | Canon NP 6050 Copier
Brother mfc8860dn copier
Open front cover with power ON
press set
read display....
choose change drum and yes/ok
close cover
will reset bias voltage aka light copies, to suit new drum
Jan 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Microwave won't start, intermittent problem
This can be caused by a bad connection on the control panel, at the fuse holder, or the thermal cutout / thermostat on the microwave. I would suspect a bad connection on the control panel which we can repair for you with our $39.95 nationwide service. We have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk I don't have an online source for an exploded view, but I may have a paper coipy here. If you are interested, follow up directly and I can see.
May 12, 2007 | Panasonic NN-S244 1000 Watts Convection /...
35 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
