Question about Electrical Supplies
Hi ,its a hondas ems 4000 in an rv , its great ,runs excellent ,with a very low laod like 5-600 watts once loaded just a little more ,lights dim down and still running and cant operate like water kettle or somthing like that.its gasoline , super maintained oil ,filter ,battery ,spark . but i dont know why it s not giving @ least 70 %. thank you very much
  • ziad35 Aug 06, 2010
    just give me some more details coz i cant get the unit to a pro and i tried to to get pro to my site but didnt happen yet,
    thanks again 4 all,
  • 5,603 Answers
THE AVR module has likely failed. It regulates the voltage as load is increased.
This ASSUMES the motor is running solidly and doesn't slow preceptively.
You can download a manual online for free at:
http://lawnandgarden.manualsonline.com/manuals/mfg/honda_1_2/ems4000_ems4500.html
Posted on Aug 06, 2010
  • 15,935 Answers
The voltage is regulated by a Regulator... and produced by a rotor/stator.
You will first need to check the voltage before and after the regulator to determine where the problem lies.
Professional help is recommended for this type of electrical servicing.
Thanks!!
Has a miss after warming up
plugs ok ? , do you have a pipe
Mar 14, 2014 | 2000 Triumph Daytona 955i
Honda ems 4000 generator starts and runs great, but no power
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
May 13, 2010 | Cars & Trucks
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Mar 22, 2010 | Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
I'm running my RV 115V 60hz a/c while connected to a 4,000 watt gas generator, with no other loads. The A/C has constant cold air, but seems to have an oscillating sound. The trailer is not completely...
this is normal, do not worry that harmonic vibration type noise just tells me that the unit has a full freon charge and is running great, sit back and enjoy
Aug 10, 2009 | Dometic Rooftop RV Air Conditioner
New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Jun 30, 2009 | Electrical Supplies
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Generac rv altenator wiring
white is neutral black is hot and green is ground
Feb 14, 2009 | Honda 6370C - Parallel Power Kit For ...
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Electrical Supplies Logo
42 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
