When i try to draw, the pen draws on the far right and not where i want it to be.
    Master:
  • 344 Answers
Run the calibration utility that came with the hardware
Posted on Aug 06, 2010
Monoprice Tablet Pen
I suspect you will eventually have to return the pen for replacement
May 31, 2013 | Monoprice 10X6.25 Inches Graphic Drawing...
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
Jun 28, 2012 | Wacom Computers & Internet
I have the et-0405-u and i want to use in with win 7 how can i get the driver and a program that i can draw scatches with it
Oh sketches! Gotcha! First of all - check that your pen actually has a 'nib' a plastic rod/insert. I reversed mine bacause it was getting worn, but it fell out and I had similar symptoms, so I have put it back in the right way round and all works fine now.
I do not know if this tablet works on Win7 - most likely does - check at Wacom.com. It works fine on Vista - just plug it in! It will be recognised straight away, mine was. If you have Windows, you should have at the bare minimum MS Paint, or whatever else it is called. If your tablet is responding and correctly recognised, opening up Paint should let you start sketching right away. But if you have any art talent at all you would be far far better off with Corel Draw (or whatever it is named these days), Photoshop or the like - far more possibilities (Corel Draw has all sorts of creative brushes and effects, I have no artistic talent but can produce great things with it).
Apr 09, 2011 | Wacom Graphire Grape (ET0405UGRAPE)...
My Wacom seems to be confused. It's acting like an etch-a-sketch. The moment I get my pen any where near the tablet is starts drawing. It can be even an inch above and it's still continuously drawing. I...
Try resetting the preferences to the default (or factory settings). This is related to proximity or pressure function. Open the preferences (with the mouse) and adjust these. Once adjusted, swop to the pen and see if this has made a difference. Trial and error… Another issue, may be the tip has damaged, or is jammed 'on'. Using the special tool provided, remove the teflon tip and clean the pen with a mild solvent.
Sep 02, 2010 | Wacom (PTZ930AC) Graphic Tablet
Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Dec 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Bamboo Tablet pen doesnt draw where i want it to
Make sure the tablet is set to "Pen Mode". It seems to do this on "Mouse Mode"...
Feb 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Pressure sensitivity problem in Photoshop CS3
Before you start Photoshop press and hold the shift key and wait until photoshop has loaded.
This should take care of the problem.
Feb 11, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Feb 06, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
Jan 06, 2009 | GTCO CalComp Drawing Board III 34180...
My cursor was smooth and easy to draw with, but now it's all shaky and won't draw well!
the latest drivers have 2 modes...
1 open the driver control panel
2 at the top of the window double click the intuos3 tablet that is giving you problems
3 choose standard mode instead of recognition data
... this is at least what worked for me. I hope it helps.
Aug 01, 2007 | Wacom Intuos3 6x11
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
