Question about Sony ICF-2010 AM/FM/SW Radio
MY ICF-2010 WORKS FINE ON AM AND FM, BUT WHEN I GO TO SYNC MODE, USB, OR LSB THE AUDIO GETS REAL DISTORTED AND IS UNUSABLE. ANY ANSWERS?
    President:
  • 1,768 Answers
This sounds like a tuning issue but not enough to go on here.
I have looked at the manual and II don't see a USB connector nor does it show a LSB connector.
If you are trying to connect the unit to your computer to record then you may have a sync issue with the software that you are recording with such as "Windows Media Player" you will have to sync the unit with the PC in this program.
http://res2.windows.microsoft.com/resbox/en/Windows%207/Main/b/7/b71f33ed-acbe-4e61-bb6f-592c4237e2ed/b71f33ed-acbe-4e61-bb6f-592c4237e2ed.wmv
Posted on Aug 06, 2010
Usb audio
need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Mar 21, 2014 | Magnum Radio Communications
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Sony icf-sw77 - listening to FM if station feq is 102.0 it's distorted so have to tune to 102.05 - what's wrong here? It's the same for all FM stations AM seems fine...
Common problem and will need realignment and / or capacitor replacement. Usually on a few are bad but I recommend all to be replaced. Contact me .... poikaa(at)yahoo(dot)com
Dec 21, 2010 | Sony ICF-SW77 AM/FM/SW Radio
Wat ar FM,AM,USB,LSB.CW. On a CB radio
FM - Freq. Modulation
AM - Audio Modulation
USB - Upper Side Band
LSB- Lower Side Band
CW- Morris Code
Nov 27, 2009 | Ranger Communications RCI-6900F-25 CB...
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
Nov 26, 2009 | Radio Communications
I have a Sony ICF 2010 (for over 20 years) and when I turn it on, the only reception I get is on the FM frequencies (+ aircraft freqs). Thank you. Alex
Late answer on this.... There is a FET problem with older radios and this could be the problem. Static can "zap" the transistor making the radio deaf on receive in the AM modes.
Aug 24, 2009 | Sony ICF-2010 AM/FM/SW Radio
Radio works fine then without warning the audio fades.
This is usually a indication of a bad capacitor, age causes this and is somewhat common. Any questions email me at.... poikaa@yahoo.com
Jun 09, 2009 | Sony ICF-2010 AM/FM/SW Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
18 year-old ICF-2010 comes to life, then dies...?
Hi Tony! Have you solved the problems? If not drop me an email at.... poikaa@yahoo.com
Rod KB8DNS
Jan 05, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-2010 AM/FM/SW Radio Logo
57 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
