Question about Linksys RangePlus WRT100 Wireless Router
My iphone 3gs cannot connect to wifi network at home. i am using linksys wrt100 wireless router.
  • 1,675 Answers
A wireless client has to support WPS ( wi-fi protected service) function in order to use to add the client to your WPS enabled Wireless Router. check the iphone user manual of your wireless client to see whether it supports the WPS function. If your wireless client does not support the WPS function, you have to configure your wireless client manually so it has the same SSID and wireless security settings, you could also go into the advanced wireless settings and enable WPS ( push and connect ) if your router has this option this is sort of specifically for things like mobile/cellular phones and ipods...hope this helps please vote thanks
Posted on Aug 06, 2010
How do I get my iPhone to recognize my new Linksys router.
passwords are case sensitive, so the problem is possibly just that you have capitals in the password and these are not specifies when entering the password into the iPhone
Jan 28, 2016 | Apple iPhone 5
My internet modems wifi light wont turn on : WRT100 Linksys
to access page you need to connect it to a pc with an ethernet cable and in web browser address bar type 192.168.1.1 user and password is admin
Jul 31, 2012 | Linksys RangePlus WRT100 Wireless Router
Can't use home wifi on iphone
How many wired and wireless computers or devices do you have?
How many are conencted to the wireless network?
How many are actually able to access Internet through wireless connection?
If your wireelss network is secured then make sure that you have the correct wireless network key.
If nothing is working then I think you should try to reset and reconfigure Linksys router.
Create a new wireless network and then try to connect to the new wireless network
See Linkssy router setup
Jan 21, 2012 | Linksys Wireless-G WRT54G Router
Change access code on linksys wrt100
Are you speaking about router about router log in password or Wireless network password.
If you want to change the router log in password then you can go to Administration tab and change the log in password for router setup page.
IF you want to change the wireless network security key WEP / WPA then you can change the wireless settings.
Dec 13, 2011 | Linksys RangePlus WRT100 Wireless Router
Can not connect ipad to router
If your Linksys wireless router is already setup with a wireless network, do the following to connect the ipad to the network:
Tap the Settings icon on the home screen of the iPad. Go to General, then Wifi. Once in the wifi section, you should see available wireless networks. Choose the network that is setup on the Linksys and connect to it. Enter the password if you have one set on the wireless network and tap join.
If your linksys is not setup with a wireless network, consult the manual for it to configure it properly.
May 06, 2011 | Linksys Wireless-G WRT54G Router
I have a new laptop and am unable to access wireless with the linksys router ( it worked on my old pc, before it died) The infor on my router reads: linksys wrt100 range plus wireless router
Check if the wireless security is ON. If yes, then you will need to know the wireless network key.
To check the settings on the router on a connected computer, use a web browser and in the address bar type: 192.168.1.1.
By default leave the username blank, then the password is admin.
Go to Wireless, take note of the SSID.
Then go to Wireless security, copy the pre-shared key/ wireless network key.
On your new laptop, view the available networks, you should see your SSID. It will prompt you to enter the network key, just type the wireless network key.
I hope this helps!
Mar 23, 2010 | Linksys WRT160N Wireless Router
I just bought a laptop with windows 7 and have a Linksys WRT100 router. I cannot set it up wireless, and have tried it all. Any ideas? Thanks in advance
Factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Nov 05, 2009 | Linksys RangePlus WRT100 Wireless Router
Linksys WRT100 won't connect wirelessly
Has the adapter in the laptop been enabled?
Ryan Frame
Creative Energy Associates Technical Center
Sep 05, 2009 | Linksys RangePlus WRT100 Wireless Router
I am not able to connect my WRT100 wireless router to my laptop, as start the installation process it stops because of static IP address on my laptop. How do i connect? Please help
On your laptop, go to Control Panel > Network Connections > Right-click Wireless Network Connection, Properties > Internet Protocol TCP/IP, Properties > Select Obtain IP Address Automatically and Obtain DNS Server Automatically > Click OK all the way out.
Hope that helps!
Nov 13, 2008 | Linksys RangePlus WRT100 Wireless Router
Unable to log on to network with Apple Laptop
The type of computer doesn't matter, as the protocols are the same. Check your router's dhcp settings, as you may have it set to allow too few IPs to be distributed.
Apr 09, 2008 | Linksys RangePlus WRT100 Wireless Router
Linksys RangePlus WRT100 Wireless Router Logo
2,124 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
