Linksys wireless 2.4 is installed on my computer and it says its working properly,but windows vista says it can not connect to linksys.
    Problem Solver:
  • 8 Answers
Have you tried right clicking the wireless icon in the task bar, select 'connect to a network' and click on your linksys information box. click on 'connect' at the bottom of the screen and follow the instructions ie enter passphrase if you have set up WEP/WPA security. did this help?
Posted on Apr 27, 2008
  • LIMAD Apr 27, 2008
    Hi - try going into wireless Network connections, right click for properties and select TCP/IP. click on the properties tab and in the next dialogue box make sure that 'obtain an IP address automatically' and 'obtain DNS automatically' are both ticked. the router uses NAT so unless you have attempted to set up your own IP address and re-programme the router, this should help. ;-}
I format my computer i need to install the linksys router
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
May 08, 2011 | Linksys Wireless-G WRT54GS Router...
Running the wizard from the install CD does not find the router and I know the router.modem cables are connected properly... whats next...
It seems you're setting up a wireless network thru your router. The basic steps in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. As of the moment, we need to use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows.
Click the link below for proper cable connections in setting up your wireless network. This also provides somewhat a checklist on what you need for wireless connectivity.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Feb 12, 2011 | Linksys E3000 Wireless Router
I cannot install Linksys E3000 intyo my laptop I tried and was asked to get intouch with you for your help in installing it
If you have Windows 7 you will run into some problems you need to go to Linksys.com and download the most recent driver and then try you will most likely have to unistall the other driver.
Chris Thrash
B52Computers
Jan 20, 2011 | Computers & Internet
How to connect Linksys WRT150N to laptop on DSL
I hope this works for you. Good Luck!
Thanks.
Mongkey
"Understanding explains better..."
Jan 18, 2011 | Linksys Wireless-N WRT150N Router
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
I tried to access my network by the adapter Linksys WUSB54GC Wireless-G USB on windows 7 but I can't. the driver with adapter for windows xp and vista I installed the vista driver, it's don but not...
You have to connect to your network without using wireless then u have to go to the linksys website and download the windows 7 driver. Install that driver then u can connect with wireless. Worked for me! Gl.
Aug 04, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I have a Compaq Vista Home Basic desktop set up to a Linksys router for my PS2, PS3 and Wii. I want to set up a second desktop computer (Windows98) that will be wireless also. How do I do that? Thank...
a win98 machine will likely have a rg-45 plug in the back, it's unlikely that may come with wireless network card. just use a straight through cable (the typical network cable) to physically connect the win98 machine to your linksys router, if you don't have any special security on your router, your win98 should be connected after a few seconds.
if you are getting a network card (possilby wireless):
install a network card on your windows 98 computer. if you're buying one make sure in the package says that it is supported by win98 (most are supported in win2k, xp, vista and 7 now so look closely before buying),
if you already have a network card and you are trying to install it, look for proper drivers from the network card manufacturer (drivers need to match model number and operating system(win98)). install your network card as per indicated in package or website if you are downloading drivers.
if you are connecting wirelessly, assuming that drivers are properly connected look in the network manager you just installed and look for the network name for your linksys router (whatever you configure that to be when your first install the linksys router) and attemtp to connect providing a password or any security requested.
in a nutshell that's what you need to do!
Mar 26, 2010 | Compaq Computers & Internet
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
