Question about Westinghouse W33001 30 in. HD-Ready LCD Television
I have a Westignhouse W33001 LCD 30 inch TV. The tv just shut off and will not power back on. I checked power supply and it has green led. Also after checking further the Main Unit Board and Power Supply connector to main board is burnt. I am sure Main Board, pwr supply and associated cables needs to be replaced. I found Main Board on internet but can't locate a pwr supply with associated cables to connect to mother board. Can you help?
  • Westinghouse Master
  • 3,866 Answers
Http://lcdpayless.com/productpage.php?productId=4780
This was listed for POWER SUPPLY and would be external now if you need the Main connector or cables within the tv you might try www.partstore.com or Matt's Eletronics for parts.
Please advise if this helped by click the accept button otherwise click the reply to expert for more clarification
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 06, 2010
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
My westinghouse w33001 flat screen tv keeps shutting off. It will be fine for a few minutes, then shut down. No power (red light out). Power cord is plugged in. Checked all connections.
It is shutting down may be because of bad power supply or shorts circuits in the backlight inverter board. You will need to do in-depth troubleshootting to narrow down the problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 18, 2010 | Westinghouse W33001 30 in. HD-Ready LCD...
Same as above
If it has sound but no raster or no picture it might be a back light problem, this could be worth the repair, check with your local repair shop and see what a repair of this type could run.
Sep 24, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
My Westinghouse w33001 30" flat will not turn on. No red light at the on button. The power supply has 12.1 vdc output & a green ind light. The connection from the power supply to the TV (seems) ok. Any...
the motor on the tv has been tampered with or has been worn out .chances are it could blow up suddenly or damage body parts when it suddleny gives a electric shock so i would advise you to receycle it comment bak
Jul 09, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
NO POWER?
HI, try a new wall outlet in the home or business. if the wall outlets are live, try replacing the power cord. if this doesn't yield results, replace the internal power unit(inverter board)
Jun 21, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Aug 25, 2008 | Westinghouse W33001 30 in. HD-Ready LCD...
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
71 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
