Question about Vtech Cordless 6041 Phone
I want to change the number of rings, from three to four or five.
    Genius:
  • 1,340 Answers
Pick up the handset.Without turning on the handset,press the function button near the bottom numbers.After you press it,you can cycle through the options with either the directional pad or hitting the function button again.Different makes have different methods.Once you get to ringset,I think the directional pad will change it.Right for more,left for less.Ithink once you select a number and move on it sets for that number.It will tell you what to press to set it if that is not correct.Hit the function button until you exit the system.Good luck!
Posted on Aug 06, 2010
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
I would like to change the ring numbers on my Panasonic KX T 7730 from two to four or five because sometimes it's impposible to get to the phone that fast
You need to enter the programming mode from the default EXTN usually 20 or 21 and change the timings of the ring counts, normally shown in seconds, adjust to 30 secs which should give you the amount of rings you need if not just go back and adjust the ringing counter seconds up until you find the length of time that suits your needs.
Aug 31, 2013 | Panasonic KX-T7730 Corded Phone
Need code to change my Toshiba model number 465l512u from cable to air
0034,0018,0072,0091,0084. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 12, 2013 | Televison & Video
ONE FOULED SPARK PLUG
Either worn valve guides, valve guide oil seals on that particular cylinder, or worn piston rings. You need to perform a compression test to find out which one of these it is.
Compression check each cylinder with all plugs removed. Take notes on which cylinder has the weakest compression.
If no compression difference and if all operating within range, then change the valve guide oil seals on problematic cylinder.
If the cylinder shows a significant drop in compression, then drop no more than five or six drops of oil down the plug hole of the problematic cylinder, and perform the compression test again. The oil will temporarily seal any worn piston rings, so the pressure should rise when retesting if the rings are worn. If the pressure remains low, then your valves are not sealing properly and require attention.
Nov 13, 2012 | 1990 Toyota Camry
Will not build pressure past 40 psi
You have either damaged reed valves or piston ring. Both of which are common problems with this type of compressor. To diagnose: Remove the motor cover, then the four screws holding the cylinder head on. The valve plate is under the head and all eight reeds, five intake and three output, must be in very good condition to work properly. You'll need the valve plate, part number N017592, and head gasket, part number Z-D24819, if there are any damaged reed valves. If they're OK, check the piston ring. Remove the screw holding the piston on the flywheel and pull the con-rod out of the cylinder. The ring around the piston must be in perfect condition to build pressure. The connecting rod kit, part number KK-4964, is the only way to get the piston seal ring.
Jan 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Phone will not ring, only vibrates even tho I use the side volumn control to choose ring volume one, or two, or three or four, or five. None work to make it ring
Hello
The reason your phone isnt ringing out is because the speaker of your phone is faulty.
The sounds made by your phone(including the ringing tone) is heard through the speaker and once it is faulty,you will not hear any sound coming from your phone.
The only solution is to have your speaker replaced.
Cheers
Mar 27, 2010 | Samsung SCH-u340 Cellular Phone
If you have a five gallon bucket and a three gallon bucket and there are no measurement marks how do you calculate a perfect four gallons
Hello! Fill the five gallon bucket...Dump its contents into the three gallon bucket until it is full...leaving two gallons in the five gallon bucket...fill the five gallon bucket...Pour the five gallon bucket into the three, filling it...Tthis leaves exactly four gallons in the five gallon bucket...
Guru.......saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Mar 22, 2010 | Garden
Ok when i hit the number 1 key i get `1 that and number 2 key brings a help manue three is ok and four is five and four and five is the same.
Your Keyboard keys is just dirty inside ; try opening it up and cleaning it up -- the circuits and touch detection underneath they key could just be misdetecting the "`" on the left of the "1" key and "2" key
Mar 06, 2010 | Saitek Eclipse II
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Vtech Cordless 6041 Phone Logo
832 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
