Question about Panasonic Lumix DMC-FS3 Digital Camera
As soon as you turn the camera on to take a picture it says, this memory card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 06, 2010
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
4 Suggested Answers
  • 18 Answers
SOURCE: locked memory card
This must be an SD card. To the left of the card is a little button that says lock and with an arrow pointing down (if i remember correctly). Just slide the button the opposite way and your good to go.
Posted on May 27, 2009
xscrewdriver
  • 246 Answers
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Posted on Jul 02, 2009
Obertelli
  • 3006 Answers
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Posted on Nov 28, 2009
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. what i do?pls explain with pictures
If the memory card is a SD memory card then
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 22, 2013 | Sony Cybershot DSCW310 Digital Camera
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
When i insert my fujifilm 2gb memory card into model jv100 all i can do is look through my pictures i cannot delete or use anything else ,and a icon comes up in the centre of the screen when i look at my...
A few things but the first that comes to mind is that there is a little slid lock on the upper left side of the memory card. This lock needs to be pushed forward towards the gold contacts to unlock the card. Another problem could be tat the 2gig card is full of pictures and needs to be downloaded to your computer. Once this is done the card will need to be formatted to clean the old pictures off and make the card ready for new pictures. I suspect when you take this card out (2gig) the camera defaults to internal memory and yes everything will work as it should until the internal memory is full of pictures as well
Dec 24, 2010 | FUJIFILM FinePix JV100 Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick.And there is nothing in the manual about how to fix it. When I turn on my camera I get an error...
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
Apr 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Locked Memory Card
on the side of the memory card theres a little slide thats normally a differant colour to the rest of the card just move this slide to its other position
Mar 25, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
My DXG model 552 is locked?
Try pulling the memory card out of camera too see if you can take a picture with out the memory card in place.
If you can do this the memory card is locked. Look at the memory card and find small swith on the side. Look for the lock symbol and be sure the switch is not in the locked position. Move the switch as needed.
Put the card back in and try it. This should solve your problem
Aug 14, 2008 | DXG Technology DXG-552 Digital Camera
Locked memory card
remove your memory card from your camera. on the left side of the memory card has an unlock switch. Just raise the switch to unlock it.
Jul 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
69 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
