Question about Brother MFC 420CN All-In-One InkJet Printer
How to replace ink - Brother MFC 420CN All-In-One InkJet Printer
  • 977 Answers
Take a look at the Manual, pg. 11-24.
Regards,
Pelu.
Posted on Aug 06, 2010
I am getting the following error. 09,038,46:15008
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
Sep 08, 2011 | Xerox Phaser 8560/YN Printer
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
My xerox phaser 8560 MFP is showing system error 09,037.45:54135 and I can't figure out how to fix the problem.
Ink count flag stuck after melting 2.5 Yellow Ink Sticks.
Initial Actions
Step 1.Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 2.
Step 2.Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt [1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
Aug 03, 2011 | Office Equipment & Supplies
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
How do you remove the ink cartridges from Canon MP890?
  1. If replacing both ink tanks, remove and replace each one individually.
  2. Make sure the device is powered on.
  3. Lift the scan unit until it locks into place. When the machine is ON and the scan unit is lifted, the paper output tray automatically opens.
  4. Open the inner cover.
  5. Hold the tab and pull it forward to release the ink tank.
  6. Lift out the ink tank.
  7. Remove the new ink tank from its packaging.
  8. Hold the ink tank and remove the protective cap.
  9. Insert the ink tank into the empty slot on the print head.
  10. If you need to replace the other ink tank, repeat steps 4 to 8.
  11. Close the inner cover.
  12. Return the scan unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  13. Press [<] to select <YES>.
  14. The LCD displays a message asking if you replaced the black ink tank.
  15. If you replaced the black ink tank, press [<]. If you did not, press [>].
  16. The LCD displays a message asking if you replaced the color ink tank.
  17. If you replaced the color ink tank, press [<]. If you did not, press [>].
  18. The ink counter is now reset.
  19. If additional ink tanks need to be replaced, replace them now.
Jan 22, 2009 | Office Equipment & Supplies
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
