Question about GE Nautilus 24" Built-in Dishwasher
I have a GE Nautilus dishwasher. I recently started hearing a clicking noise during my dishwasher cycle. It seems to becoming from behind the access panel on the left hand side of the machine. There are no draining or wash problems - just this new noise.
  • 214 Answers
The pump/motor assembly on these dishwashers have a soft food cutter that helps to cut up smal soft food particles. This may be your problem.
These cutter blades can sometimes get loose or something can get hung up in them like a broken piece of glass or some other pieces of trash that they can not handle.
You can access these blades by removing the sump cover near the rear of the bottom of the inside of the dishwasher. remove the bottom rack and take a couple of screws out of the sump cover. you can feel down in the sump and see if there is any trash caught up here or in the blades.
If this is not the problem and you have an older dishwasher - you could have a problem with a loose fan blade in the motor. If this is the case I would run it til it dies. The motor/pump assembly is about $125+. The newer motors are a lot quieter.
If everything is working ok. I wouldn't worry too much about it.
Posted on Aug 08, 2010
  • 166 Answers
Posted on Aug 06, 2010
  • coohead Oct 02, 2010
    Well....that sure was helpful!
    How about the same machine not pressurinzing the water to spray around in there??
    The motor is spinning. It just quit pumping...just gurgles out of the spray mast.
    Any ideas on that?
    Coo
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is making a very loud rumbling noise at certain times during the wash cycle. it's a ge nautilus
That usually comes from the main wash head being reinstalled without the white washer which provides a smooth surface for it to glide on, or it has cracked and fallen off, OR it's mounter to the head and has simply eroded.
Mar 11, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Jan 02, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
523 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
