Question about Kyocera Copystar CS-5035 Copier
Ii need to change the number of rings before the fax machine answers on my Copystar CS 5035. How do I do this.
  • 113 Answers
Touch the menu button, go to fax default, key in code 6482 and then scroll settings and change the the number of rings
Posted on Aug 10, 2010
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Jan 09, 2013 | Kyocera Copystar CS-5035 Copier
Download printer driver for cs 5035
go to www.copystar.co,
look under download, choose legacy black and white copiers MFP
the under the subcategory select print driver, choose the KX driver thats support your windows version, then run it and you good to go. let me know!
Nov 23, 2011 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
C-1120 on a CS 5035
The LCF lift 1 is not working
Jun 10, 2011 | Kyocera Copystar CS-5035 Copier
I would like to change the name on my scan to PC function on my CS-5035...right now it is set as Angela and I need to change that name to Shannon
go to internet explorer, type the IP address of the scanner, go to destination list on scan to pc. click your number where your name is appearing. change name and the click registration.
Sep 30, 2010 | Kyocera Copystar CS-5035 Copier
I am just trying to find the driver for a Copystart CS-5035. I cannot find anything on the Kyocera web site.
www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Aug 03, 2010 | Kyocera Copystar CS-5035 Copier
I was told i needed a fax module to be able to fax from this copier where would i be able to get this and how would i install it
You need the fax card in order to use the machine as fax unit too. let me know if you still looking for that, so i can send you the manual to setup it.
Feb 25, 2010 | Kyocera Copystar CS-5035 Copier
I have a kyocera cs-1650 with the error message FAX MODE ERROR. can you help?
It is problem Program not properly configure.set up fax program,Fax line type,Receiving mode,number of ring count.Other help follow your copier User Guide manual.If you do not fix your problem then you call a service technician. who support this machine.
Dec 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Touch screen on kyocera 5035 isnt working
Look for a stuck key on the operation panel. Usually is the least used key, a grain of salt will do it!
Jan 27, 2009 | Kyocera Copystar CS-5035 Copier
Kyocera Copystar CS-5035 Copier Logo
203 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
