Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
MY SONY TV WILL NOT COME ON WHAT DO I DO
  • Sony Master
  • 8,617 Answers
Is the power indicator blinking? If so count the number of blinks in between the brief pause as thats an error code which is indicating which circuit has the problem.
Posted on Aug 08, 2010
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
It is a Power Supply board and is a part shared with some Sony televisions.
Sony Power Supply Board A1300319A KV32HS500 ... - eBay
www.ebay.com > ... > TV Boards, Parts & Components Sony Power Supply Board, A1300319A, KV32HS500, KV34XBR800... (280925870381) in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio ...
Sony A1300319A SONY A-1300-319-A COMPLETE PC D ...
www.amazon.com/Sony-A1300319A-A-1300-319-A...BOARD/.../B001... THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONY TELEVISIONS. PLEASE FOLLOW THE LINK ABOVE FOR ...
Sony A-1300-319-A D Board, Complete - Encompass Parts
https://www.encompassparts.com/.../Sony/A-1300-319-A/D_Board,_Co... Image, Manufacturer, Part Number, Description, In Stock, Part Price. Pts Modules, A-1300-319-A, Sony - D Board (Deflection & Power), 271.90 ...
A1300319A, A-1300-319-A Sony TV Module, D
www.tristatemodule.com/A1300319A-A-1300-319-A-Sony.../a1300319... US$148.00 Part Number: A1300319A. Board Numbers: . TV Models: KV-32HS500, ... Home > TV Parts > PC Board > A1300319A, A-1300-319-A Sony TV Module, D ...
Jan 30, 2016 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
How to play mkv files in sony bravia kdl32ex550
Currenly Sony TV and Palystation only supports videos in MPEG-1, MPEG-2, MP4, WMV, ASF, DivX HD.
In order to play MKV on Sony TV, we had better convert MKV to Sony TV compatible format.
Feb 06, 2014 | Televison & Video
Sanyo tv avi unsupported file
Maybe you have reported that AVI and some other formats not supported by Sony TV, in this case how can we play AVI files on Sony TV from USB flash drive? Please don't worry, now we will share the best AVI to Sony TV converter - Pavtube Video Converter with you, which can help you to convert AVI files to Sony TV USB supported format, and then you can play videos on Sony TV with compatible format.
Reference: Watch MP4/AVI/MKV Files on Sony TV from USB
Apr 12, 2013 | Sanyo Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
Replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Nov 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
Jan 26, 2009 | One For All URC-4330 Remote Control
Volume buttons of Sony Remote control is not working for Akai TV.
Volume buttons on Sony remote will work on Sony TV only.
Aug 04, 2008 | Sony RM-V310 Remote Control
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
