Scanner error 6
My hp 3052 suddenly stops, and there is a display "scanner error 6,turn off then on" Of course i did turn off and on several times but it keeps on coming back.
  • 6 more comments
  • Anonymous Jun 13, 2008
    i have same problem
  • ilkyardim Jun 13, 2008
    i have same problem :S
  • Anonymous Jun 27, 2008
    yes
  • neekal Jun 27, 2008
    yes i have same problem i have turned off so many time but no solution
  • patelhani Aug 08, 2008
    i have facing problem with HP Laserjet 3052 printer " Scanner error 6 Turn Off ON printer" , on printer display panel
  • Anonymous Oct 01, 2008
    I have scanner error 6 too
  • padma v May 11, 2010
    scaner error 6 is displayed on the printer can any one fix it?
    scanner error 6 displayed on the printer... can some one fix this?
Posted on Feb 06, 2010
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Error escaner 6
first update firmware, still same issue this problem occur when any scanner gear failure time...
Apr 14, 2014 | HP LaserJet 3052 Printer
Error scanner 6
remove the scanner glass & remove the scanner glass alignment black & white sticker clean it with white cotton white should be bright white then fix the same with the same position & try upgrade the firmware
Apr 14, 2014 | HP LaserJet 3052 All-In-One Printer
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
(error 6) turn off then on hp laserjet 3052
Hi
disconnect the printer cable (USB Cable / Data Cable)
and swich off and on the printer...... it will solve the problem
In case i have help you pls vote me
Nov 04, 2010 | HP LaserJet 3052 All-In-One Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
Hp 3055 adf
Here's a link to the full service manual for your HP 3055. It's too large to post here (15MB) but I've hot linked it for you so you can download it to resolve your issue with the ADF. Look at pages 44 thru 46. Pay special attention to the rubber pad (separation pad) that is under the 2 roller peice as it is what keeps the doc feeder pulling one sheet at a time.
Hope that helps you. If so hit me with a FIXYA, If not send me a message or reply and I'll try and walk you through it.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/lj3050-3052-3055aio/Q6502_service_enww.pdf
Sep 02, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
2,048 people viewed this question
jasbo
jasbo
