Question about Refrigerators
I have an Artic Air Refrigerator model r22cw7. It is not getting cold, the compressor is very hot and the fan inside was not spinning. I unplugged and let set overnight. This morning i plugged in , heard motor running, fan is spinning and fridge has cooled to 40 degrees in about 30 minutes.\r\nIs my compressor going bad? relay? switches?
3 Suggested Answers
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
heatman101
  • 43501 Answers
SOURCE: Refrigerator is not cooling properly
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Posted on Apr 12, 2010
Testimonial: "Thanks for the tip. I have cleaned it in the past at the suggestion of another service tech who came out for a "recall" repair in March 2009."
Zfk56/52 not cold fan running compressor is hot to touch
Compressor getting hot is normal. Fan working is good. Make sure the inside fan works and that the vents are not blocked. Vacuum under the refrigerator so the air can circulate to the condenser coil. Good luck!
Dec 22, 2016 | Refrigerators
My Hotpoint side by side refrigerator wont keep cold but the freezer is working fine. I unplugged it and felt the compressor it was hot. The fan and coil was covered in dust. I cleaned it off and wasn't...
There is only the coil in the freezer and a fan moves the air to the refrigerator. Check the fan inside the unit. IT might also be icing on the coil that is causing no air flow.
Aug 19, 2014 | Refrigerators
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Jenn air refrigerator model jbr2088hes is not cooling fan is blowing and cool air is coming into refrigerator
A compressor can naturally get hot the tech leaving parts on the floor is wrong the real way to tell if the compressor is bad is to unplug the fridge find the thermostat and unplug the two wires that plug into it then make a small jumper wire with two male spades and a two inch peice of wire and plug it in to both of the wires that you unhooked from the thermostat then plug in the fridge and wait 20 min if the fridge gets to normal cold which is 37 degrees or less it's not the compressor it's the thermostat but if it don't get any colder than before it may be the compressor but a new fridge is less that 500 dollars
Mar 12, 2014 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Emerson Compact Refrigerator not cold.
Make sure the condenser fan is running, it is located near the compressor and blows across the condensing coils, and make sure the coils are clean. Compressors usually do get pretty hot though. And make sure all you fans are running in the inside
Aug 21, 2009 | Emerson Refrigerators
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator is not cold or freezing in freezer.
the gurgling sound is normal, its the freon inside the evap. .the compressors also runs at a very high temp. , there is only 1 fan that circulates cold air, there is another fan but it is the cond. fan which blows hot air located at the bottom near the floor
May 06, 2009 | Refrigerators
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
