Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
What is the external parts of motherboard - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
  • 977 Answers
I guess it mean the "side" of it, where all the rear connections are... It's what you can see looking at the back of your computer case.
Posted on Aug 06, 2010
External parts of computer with definition?
Hello ri_rahim01,
click on the {URL Link} below, you can
"Download a User Guide / Manual
that will give you the Specifications,
of 'all' the "Motherboard's" parts with "descriptions of each!
"Give a "Helpful Rating"; if you are satified?
Thanks, paul7of9
Click here for "Manual" http://www.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
Oct 04, 2011 | Intel D865GBF Motherboard
Part of the screen stays white in my nc150 netbook Looks like it's a left 1/3 of the screen is always white with some thin black and white vertical stripes but the rest of it works fine. I would like...
Paul -
This absolutely could be the ribbon cable connecting your screen to your motherboard. If you know how to check this, it would be worth trying before spending $150+ on an LCD. Any way you look at it, this is definitely a hardware issue. Just hope it's not the motherboard's onboard video card. Here is a modified answer I gave to a question similar to your issue:
If you turn on your laptop and the display is bad, your issue is with either the LCD screen or the motherboard (since the video card is built-in the motherboard). This will be easy to diagnose.
1.) Plug an external monitor (one which you know works) into the VGA port of your laptop.
2.) Turn on the laptop.
3.) Hold down the FN key (lower-left corner of the keyboard) and press the "CRT/LCD" key (it will be located on the number keys or F1-F12. You do this to tell the laptop that it needs to send the video signal to the external monitor instead of its built-in LCD screen.
If the display is good on the external monitor, then the issue is with the laptop's LCD screen (about $200 for the part plus labor to install). If the display is still messed up on the external monitor, then your problem is with the motherboard ($300-$500 for the part plus a lot in labor cost for installation).
Let me know if this helps you!
Sep 30, 2011 | Computers & Internet
Toshiba satllite power on no display
Possible that the LCD panel is faulty , possible that the linking wire to the LCD panel is open.
Connect an external display to the PC and if the PC boots and works without any issues then the fault is associated only with the display. It can be a power issue to the panel, loss of back light or drive from the motherboard.
You need to trace and check continuity from the motherboard to the display unit to confirm.
Sep 21, 2011 | Toshiba Satellite Pro L300 Notebook
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
View screen only 1/4 readable
Connect to an external monitor, see if the display is normal there. If it is, then reseat the LCD cable connection on the motherboard. If LCD is still messed up, then replace the LCD.
If the problem is the same on external monitor, then replace the motherboard.
Apr 15, 2009 | Dell Inspiron 1100 Notebook
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
