Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
My sony model kp46wt510 pic looks like its in 3d, what is the problem?
  • Sony Master
  • 8,457 Answers
Tv have a problems known as a convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors are dead,require changing.These parts on the tv convergence board,must have to replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Aug 06, 2010
SONY BRAVIA 3D ANDROID TV MODEL-43W800C 3d active or passive in bangladesh? Which 3d glass required?
A 3-D glass won't be effective; especially in Bangladesh. A 3-D mirror; which look like a (kaleidoscope) is needed to see images in 3-D; in your country. Look for that.
Jul 04, 2016 | Sony Televison & Video
My sony kp46wt510 the color is out foccus.
Install a convergence repair kit. The Sony Type 1 convergence repair kit works for your model. Its available from www.tvrepairworld.com and it has the CD with detailed instructions.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony kp-65ws500 is like it is in 3d and bowed
The Sony KP46WT510 convergence repair kit available at www.tvrepairworld.com should repair that issue. The kit works for your model and includes the CD with instructions.
Oct 29, 2009 | Televison & Video
My sony 46 kp46wt510 panel tv has red outline on images
its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board inside the KP46WT510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Convergence problem
you need to replace the convergence ICs, pico fusses and possibly a couple of the feed resistors. you can get the kit for your model at the following link which contains the parts and instructions.
Jan 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red's are out of alignment and I can't fix them
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
Jan 24, 2009 | Sony KP-51WS510 51" Rear Projection...
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP46WT510 Projection TV
pic of ic known as SDK's
41ae87f.jpg Heat sink is a hunk of metal attached to above
on a sony the convergence board is known as "d" board labeled with a big D
see
LINK
Jan 20, 2008 | Televison & Video
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
