Hi i use a peavey 6505 Amp head and when i run a seymour duncan pickup booster through the effects loop it blows the amp (possibly the pre-amp fuses) i want to get a volume boost in a distorted setting hence using this pedal, when i run it through the front it doesnt increase the volume in this mode, only in a clean mode. any suggestions what i can do to stop the head blowing ??? Regards Alan
  • 1,512 Answers
Hi bmwz43
Odd that you keep blowing the head... and with 5 12axl preamp tubes even more surprised that you cannot get enough gain... :) Get the correct pedal for the 6505 and change yo levels that way. Hard to beat classic tube amp for tone:)
Check the the amp has the correct impedance setting for the quaddy you are using.
One more thing, what sort of cable do you have connecting the amp to the speaker box. If you use a cheapo guitar jumper lead arrangement, expect that to give you trouble AND **** tone. The 6505 has 120watts of cranked up tube output. Tube output stages need a solid at least 18 gauge cable and quality connector jacks, like Switchcraft. They can blow fuses if you don't use a decent speaker connector lead.
Get back to me here if it does it again, and check to see exactly which fuse you are replacing. It can help sort out the problem.
regards
Graeme
Posted on Apr 27, 2008
Peavey classic chorus 1991 -how do you connect a distortion pedal the power amp jacks at rear tried affects loop in front bid drop in power-do you connect same way as effects loop with send /return
Pedals operate at a different level then rack units that go in the effects loop.
It needs to go in front of the amp input. Guitar to pedal to amp input.
Nov 12, 2016 | Peavey Music
I have a Peavey XR-600 PA Head, I would like to know if and how can I connect a MX 200 Dual Reverb Effects Processor to the PA Head?
If it has a effects loop output and input on the p.a. head and a in and out on the reverb effects processor, then yes you can, just run the effects loop output signal into the input on your reverb processor, out of the output back into the input effects loop on the p.a. head, kinda like you would a effects pedal thru the effects loop of a guitar amplifier. hope this helps!
Dec 02, 2015 | Peavey Music
Brand new Peavey 6505. Worked fine first day but now just blows fuse and doesn't even turn on. Will be going back but has anyone got any ideas?
Something internally has shorted...not a good indicator of this models reliability. It may pay to research another replacement brand.
Dec 28, 2013 | Peavey 6505 120w All Tube Head Guitar...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
67 people viewed this question
 Grubhead
Grubhead
