Question about Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA, MP3, WAV CD Player
Every time i turn off the the deh 2900 , stored radio stations are lost. how to store stations without losing them ?
  • 39 Answers
This issue is caused by the deck not being hooked up to the constent from the cars battery take the deck out of the dash and get the color codes for the car and the deck and find the wire thats for the constant from the battery and hook up thoes wires
the wires are usually labeled on the deck as follows
labeled wires
red .......... ACC
yellow......+Battery
blue ........ system remote control/remote
unlabeled wires
green ...................................... speaker+
green with line ......................... speaker-
purple ..................................... speaker+
purple with line ........................ speaker-
gray ....................................... speaker+
gray with line .......................... speaker-
white ...................................... speaker+
white with line ......................... speaker-
black ..................................... Ground
orange ................................... dimmer+ (usually not used)
orange with line .......................dimmer- (usually not used)
i reccamend you to get the plug in harness that has the wireing alredy done you only have to match up the colors
i hope this helps
Posted on Aug 06, 2010
Testimonial: "Thank u very much, helped, problem solved !!!"
Motevo gtv x3 touchscreen: I don't know how to set radio stations. Once I find a radio station I try to store it, but I don't have a clue how. Can someone explain it to me or tell me where I c
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
Oct 22, 2012 | Motevo GTV-X3 - 6.2" Touchscreen...
How do i preset my stations on my deh-p400ub? thanks in advance
Here's the relevant instructions out of the manual.
Storing and recalling broadcast frequencies You can easily store up to six broadcast frequencies for later recall. ! Six stations for each band can be stored in memory. 1 Press LIST. Preset screen is displayed. 2 Use MULTI-CONTROL to store the selected frequency in memory. Turn to change the preset number. Press and hold to store. # You can also store the frequency in memory by pushing and holding MULTI-CONTROL right. 3 Use MULTI-CONTROL to select the desired station. Turn to change the station. Press to select. # You can also change the station by pushing MULTI-CONTROL up or down. # To return to the ordinary display, press BAND/ESC or LIST. # If you do not operate the list within about 30 seconds, the display automatically returns to the ordinary display.
You can find the full manual here: http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP4000UBOperationManual1019.pdf
Aug 20, 2011 | Pioneer DEH-P4000UB CD Player
When you locate the stations and store them then leave the car for any period of time or turn radio off, all the stations you previously stored have all disappeared and you have to retune again!
There are 2 battery supplies to the radio,.
The main one via the ignition key circuit for the radio itself.
The other one is a permanent battery feed to the radio memory.
It is this second (permanent) feed that is missing.
Check the fuse, connectors + wiring to see if there is anything obvious.
If you have a multimeter or test lamp then that can be used to prove the problem
Sep 04, 2010 | Pioneer DEH-P4100
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
Pioneer deh4000ub radio wont save
Six stations for each band can be stored. 1 Press LIST.
frequency in memory. Turn to change the preset number. Press and hold to store. You can also store the frequency in memory
Jul 18, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Setting my stations on my Pioneer DEH-27mp
the yellow wire on the radio's harness must be connected to a 12 volt line that has power regardless of the key switch position, If not the radio loses its "Memory" every time you turn off the key
May 06, 2008 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA, MP3, WAV CD Player Logo
151 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
