Question about Insignia NS-LCD47HD-09 47 in. LCD TV
Insignia NS 15" LCD Problems power light on power supply but no screen
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
ginko
  • 19396 Answers
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
John-INSG
  • 312 Answers
SOURCE: I need a Power Supply For Insignia TV Model
You can order parts for your TV here. Select your exact model for available parts.
Posted on Sep 30, 2009
John-INSG
  • 312 Answers
SOURCE: insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Posted on Oct 01, 2009
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia ns lcd 32 wont power on
When you plug in the set, does the standby light come on? Most likely you are dealing with either a failed power supply or main board. I would start with checked the power supply for bulged capacitors.
Dec 15, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
Tv has sound but no picture
This is almost certainly a problem with the backlight power supply, not the ac adapter. If the backlight isn't working, you will see nothing on the screen.
Aug 30, 2012 | Insignia NS-LCD15 15" LCD TV flat monitor...
I have an insignia ns-lcd37-07 giving to me, i replaced power supply board and i still don't get anything. what should be my next step?
Now the tv is turn on,tv have power LED light indicaton but no picture?Still have a clicking sound but no picture on the tv LCD screen panel?Yes,than the tv Tuner signal board that the other board 70% also might have the problems too.That the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 13, 2011 | Insignia NS-LCD37 37 in. LCD TV
Insignia NS LCD 37
Sounds like the power supply board have problem, but if you provide the model; and version. And more detail, may get better helping.
Knowledge obtain from: Repair experience on same symptom.
May 02, 2010 | Televison & Video
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
I have an l.c.d t.v. and the pic went black and the vol. is out but the power light is still on and it blinks 15 times
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
You can get parts here:
http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+NS-LCD37+
Dec 09, 2009 | Insignia NS-LCD37 37 in. LCD TV
When i turn on tv screen is bright white instead of blue!!!
This is a problem that should be taken in for service as there could be many problems causing the problem. The power supply could not be supplying voltage to run the video card or you could have a failure in the video card itself. Try calling this number for Insignia Customer service help. 1-877-467-4289. Hope this helps you with your problem.
May 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Insignia NS-LCD47HD-09 47 in. LCD TV Logo
379 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
