Question about Nextar Q3 GPS Receiver
Turn on and I get the logo screen, loading bar is about 1/4", plug it in to current and nothing happens. push menu - nothing!
  • nestlergus Aug 07, 2010
    Q3, does not load. get nothing when turned on! the load indicater is 1/4 inch and does not move. I do not have the mem card. menu does not appear.
    can I plug into my LT and download from th begining?? I think the unit is a goner, a new system may be in-store. where do I go on the net to down load?
  • 15,935 Answers
What is the model # of the unit please??
Thanks!!
Posted on Aug 07, 2010
    it's a Q3, ser#ML0704000075, manu. april 07, Win /ce NET 4.2 Core
    X11 - 15297
  • 10,865 Answers
Hi. ou should try to reset the unit.
To reset first switch off the unit then Disconnect the unit from power supply/batteries then disconnect any other units connected to it, after that Leave it disconnected for 30 minutes. It should reset itself then start again.
---------- the other procedure to reset is ------------- press the power button on the front of the unit until it shows the logo screen (about 1 second).the unit will then reset. It takes about 55-60 seconds total to restart and, best of all, the RAM contents including the registry are all intact after it reboots. try both procedure if the first one does not help.
This will help. Joe
  • 4,323 Answers
Hi
Try removing the memory card and check whether your issue is resolved, If it is resolved then you'll need to clear the data from the SD memory card. If the issue is still unresolved then you'll need to press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it is caused by hardware failure. Connect the GPS reciever with the computer and then disconnect the wire after the device has been identified.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 06, 2010
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Sep 19, 2013 | Samsung Televison & Video
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
When turned on screen lights up with apple logo but nothing else happens
reboot while holding the option key down. It should show you available hard drives from which you can startup.
Choose the drive and then press return or enter.
Then restart.
If nothing happens, turn off the laptop and insert your Mac OS disk and then reboot while holding down the C key.
The computer will load the system on the disc instead of your hard drive. Then instead of reinstalling the system software, look at the top menu and find the Disk Utilities program and run a repair on your hard drive.
Then reboot without the disk in the drive.
May 10, 2010 | Computers & Internet
Computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
Windows not loading
Sounds like you have a nasty virus that has corrupted your harddrive
so that means that the recovery portion is corrupted as well
you need the operating system and reinstall everything
Mar 12, 2009 | HP PAVILION M1072N MEDIA CENTER - P4 530...
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Start menu
Preventing programs from automatically loading If you see the program you wish to remove however have Windows 95 click Start / Settings / Taskbar & Startup Menu / click the Start Menu programs tab
Good Luck/Please dont for get to Vote. Thank you
Dec 14, 2007 | Compaq Presario 5000 PC Desktop
Ipod nano
switch the hold button on and off, then hold horizontally, and push the menu button and center button at the same time. hold them down untill the ipod restarts and the apple logo apears. If that doesen't work, plug into the newest itunes program, and push restore.
Feb 26, 2007 | Apple iPod nano
Nextar Q3 GPS Receiver Logo
20 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
