Cant hook up rf input to sanyo 30" flat tube tv?
    Brigadier General:
  • 6,966 Answers
If I understand your problem right and if you are in the US, it is possible that the Sanyo flat tube TV is using a PAL cant hook up rf input - 650e91e.jpg type female antenna (RF IN) connector while your cable (or aerial) coaxial cable is terminated and using an F type 398377c.jpg. What is needed is an adapter to convert the F to PAL 254abcd.jpg. These are readily available at any electronics parts store.
Should I have mis-interpreted your concern, would appreciate a post back with clarification.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 27, 2008
How to hook up VCR
Use Audio video cable from a VCR to TV input jacks. Select AVI mode from input box option of your TV. The second way is connect RF cable with VCR to RF jack of TV and auto search again your TV channels.
May 26, 2014 | Element Televison & Video
Why doesnt my 32" SINOTEC PLAY MY PLAYSTATION 2
where did you hooked up your ps2, in component input in your tv or through RF tuner of the tv. it will depend which input or you are using so you can set the tv in the right option.
May 12, 2014 | Sanyo Televison & Video
What do I need to do to hook up cable to this tv?
This TV has the following inputs:
RF input, composite video/audio input
The easiest would be to use coax cable
Aug 11, 2017 | Sanyo DS24205 24" TV
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
I don't know how to hook up my Sanyo DVW6000 VCR. A friend gave it to me minus the user manual and remote control. How do I get a control to operate it? That is another problem.
All you need is to connect the RF output to the RF in of the TV or the audio output . video output to the corresponding AV input of the TV. Then put in a tape and press play.
Youc an get manuals from this link:
www.caraudio.manualsonline.com/ex/thread/view/idThread/???96428
www.devicemanuals.com/guide/???VCR/???Sanyo-manuals.html
Oct 05, 2010 | Sanyo Televison & Video
How do I hook up a VCR to a small Sanyo TV? Thank you
How you hook up the VCR depends on the connections available on the VCR and the TV.
The simplest method is to use a cable from the VCR's RF (antenna) output connector to the TV's antenna input connector and tune the TV to the VCR output channel (3 or 4). You might need to purchase an adapter to switch from the standard plug on the cable to whatever kind of external antenna connector is on the TV. If the set only has a built-in antenna and no external connection at all (which would be quite unusual), you need a "balun" transformer. This has a connector on one end for the cable from the VCR and a flat wire with two terminals on the other end. Attach one of the terminals to the set's antenna with a clip-on jumper wire. Radio Shack sells the parts.
If your VCR does not have RF output but just audio and video jacks, connect those to the TV's a/v inputs if it has them. Again, an adapter cable might be required.
If the TV doesn't have a/v input available, you need an RF converter. This takes the a/v signals from the VCR and produces a channel 3 or 4 output that you can connect to the TV as described above.
It sounds more complicated than it actually is. Once you look at the VCR and TV, and remember that outputs always go to inputs, it's usually pretty clear what needs to be done. If you still have troubles please post a follow-up comment and I'll try to help more.
Apr 22, 2009 | Televison & Video
I HAVE A SAMSUNG MOD. NO TC9823S, LOST REMOTE I WANT TO HOOK A DVD UP ON THIS TV, CANT FIND INPUT CHANNEL, CAN YOU HELP
You need a RF Modulator that outs the signal into the cable input because the TV has only a video input (yellow) but no audio in, only audio out. Radio shack has one for about 29 dollars.
Mar 22, 2009 | Sanyo DS31520 31" TV
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Sanyo TV - DS25390
In your model you have to purchase one video RF converter. RF converter contains one video input in yellow colour and two audio input in red and white colour and one cable connector as output. Connect the dvd output to this converter and tune the tv program in which place you receive dvd signal.
Aug 26, 2007 | Sanyo DS25390 TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
