Question about General Electric GE 13-438 Overhead Garage Door Switch
My system has been working for eight years with no problems. All of a sudden stopped working. Light at the back of the unit blinks and the light bulb is on all the time. Dont think its the hand held remote control is the problem as the unit flashes we pressed. TH unit is a moter lift 2000. Any help is approcated. The light bulg is on all the time and there is no response or noise form the moter. Also replace the batteries in the remote control.
    New Friend:
  • 130 Answers
A Bad circuit board will cause the above problems. All it takes is a power surge or sometimes just age.
Posted on Aug 09, 2010
My Kenmore Ultrasoft 400 water softener tome light will not stop blinking. How do I reset it
It's been 10 years since I worked at EcoWater, but the Kenmore Ultrasoft 400 shouldn't have changed much. The brine tank light shouldn't blink at all. It should light for 4 minutes and then go out if you leave the door open if I remember correctly. How old is your softener and does it have a light bulb or an LED to light up the brine well? It's most likely a damaged control board that's creating your problem. You'll have to contact Sears for a replacement.
(EcoWater Systems LLC is the OEM [Original Equipment Manufacturer] of water softeners for Sears Kenmore, GE, Whirlpool, Morton Salt, EcoWater Systems dealers and a few others.)
Sep 03, 2016 | Water Dispensing & Filtration
I have WGT624 v2 used for years and in a pretty good condition. Unfortunately, it suddenly doesn't work recently. No internet connection at all. The power LED light keep blinking and the color change...
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | NetGear WGT624 Wireless Router
The right turn signal comes on but intermittently it makes long duration of blinks. Sometimes both the right front and right rear will be energized in the on position but will not blink at all. We have...
You say it's the right turn signal that is malfunctioning. If the left works correctly, then the problem is most likely NOT the flasher unit. That unit provides the flash for both left and right signals. I think that flasher unit is mounted on your steering column, down under the dash. It will probably be an aluminum cylinder, but may be a rectangular black plastic block. Before you change the flasher unit, I'd suggest checking the front and rear turn signal light bulbs. On the front, those are the parking light bulbs, and on the rear are the stop light bulbs. You may have a poor connection, probably from corrosion, or the bulb is very nearly burned out completely. Good luck.
Oct 23, 2010 | 1996 Buick Century
Chevy Cavalier 2001 turn signal blinks fast
If new bulbs don't work, it is probably the harness that holds the bulb. I had to replace both on my car after fighting with the problem for over a year and not knowing.
Nov 26, 2008 | 2001 Chevrolet Cavalier
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Whirlpool dishwasher
I had the same problem with mine awhile back. I tried clearing it out like the book said and it would start blinking again when I started it. Then it wouldn't do anything. Based on research, I decided to replace the heating element and that solved the problem. Of course, now a year later, I am having other problems.
Aug 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Just went black without warning. Now won't come on.
What does the power light do when you press power? Does it blink? Please respond to this same post and I will try to help you with the problem.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
My tv wont turn on
youre in trouble check the other posts
Aug 07, 2007 | LG 52SX4D 52" HDTV
My TV doesn't show the image/picture
ya thats the standard line from the twenty somethings at the stores now suddenly 15 years of crt tvs all magically have bulbs like a dlp tv these are the same people that they interview on the street and ask who the president of the united states is your tv was originally made by samsung if you read the sticker on the back no user serviceable parts... its kinda like the tag on a pillow any way there is circuit board with two parts on an aluminum heatsink unplug the tv of course take off the back panel and uplug the red plug from the circuit board with the two black modules labeled stk392-040 this whole board can be replaced for 70 dollars parts store dot com
Dec 07, 2006 | Akai PT4298HD Rear Projection Television
General Electric GE 13-438 Overhead Garage Door Switch Logo
Top General Electric Electrical Supplies Experts
Craig Butler
Craig Butler
David Harrelson
David Harrelson
Steve
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
