Question about Westinghouse 32" Flat Panel LCD HDTV
The television keeps automatically shutting off when turned on
  • 11,361 Answers
The power supply may have gone into shut down mode due to problem in the power supply such as bad DC filter cpas, or shorts circuits in the backlight inverter board, those are the two areas you need to check first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
My tv keeps shutting itself off automatically and the temp light keeps flashing.
this is a job for a service tech, because you are having problems with what it seems to be thermal shutdown. please refrain from turning it on you could cause further problems to set.
Nov 06, 2009 | Hitachi 42V710 42" Rear Projection HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Philips 43PP8421 turns on and off
check to make sure that you dont have any timer set, it seems that you just have the timer set to 15mins and it keeps repeating just simply turn off the timer if this is the case.
Apr 21, 2009 | Philips 43PP9202 43" Rear Projection...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Setting automatic shut off
How do I set on PCB to automatic tv shut-off?
Jun 29, 2008 | Curtis-Mathis CM19011 TV
In RCA T13208 13 in. TV/VCR Combo shut down after turn it on
The safety circuit is sensing a problem and is why it will not let the tv stay on,the cause could be a problem on the mechanics of the vcr,you need to get an estimate to see if it is worth the repair and might be able to keep using just the tv.
Sep 23, 2006 | RCA T13208 13 in. TV/VCR Combo
Westinghouse 32" Flat Panel LCD HDTV Logo
73 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
