Question about Hotpoint Refrigerators
Hotpoint model HSS25GFTCWW side by side refrigerator/freezer. Freezer side is working great, refrigerator side is not cooling properly. I've reset the temp, no change, cleaned the vent in the back,still no change.I've made sure it seals when the door is closed, moved things around so air can circulate, but I do not feel any air coming from the inside top vent. There's no moisture, or water dripping or pooling under it. It is 3 years old.
  • 534 Answers
SOURCE: moisture dripping from temperature control hood model KTRS21MFAL0
possible that condensation drain line is clogged. This line drains the water from the freezer when it goes into defrost to a small pan loscated above the compressor where when it gets to the pan the heat from the compressor running evaporates the mosture.
Posted on Apr 16, 2009
lsteward68
  • 331 Answers
SOURCE: Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
Posted on May 26, 2009
pride applia
  • 232 Answers
SOURCE: Refrigerator warm, freezer is fine.
this could also be a plugged defrost drain ice building up blocking air flow through the return vents is therehwater dripping into frige
Posted on Jul 01, 2009
  • 272 Answers
SOURCE: freezer frosting over vents, refrigerator not cold enough
Greetings,
i work on this for a living 33 years..sight unseen, I'd say the evaporator is froze over. Its missed its defrost..I suggest leave freezer door open and unplug for 24 hours to melt ice..There still will be a problem and this will continue, but this gives you temporary service. You;ll need a repair-person to fix it. The evaporator frrezes over blocking airflow to fresh -food section. This in turn can cause a fresh food and freezer failure..
Bruce Denton appliance tech 33 years...
Posted on Jul 05, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Have an 8yr old Kenmore top freezer. Water is
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Posted on Mar 30, 2010
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Freezer is freezing cold... but refrigerator is not cooling good on side-by-side Hotpoint Model HSS251FMDWW. What number should it be set on??
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 31, 2011 | Hotpoint Refrigerators
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
My freezer side is not cooling properly
I would say that you have a small leak and are looking at major problems down the road...
Checkout this tip that I wrote about that...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Apr 21, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
MAYTAG MSD2354ARW
How great is the freezer temperature? Look for frost on the freezer back wall. If there is frost there you have a defrost system problem.
the refrigerator is cooled by air it receives from the freezer. When the freezer coil freezes up the air circulation stops.
May 30, 2008 | Hotpoint HSS25GDMWW Side by Side...
Refrigerators Logo
102 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
