Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Parts for a Ryobi hedge trimmer RY15703 in the Seattle, WA area. This is a expand-it unit for a Ryobi string trimmer, model number SS-RY34441, a 30cc 4-cycle model. The hedge trimmer parts numbers for the parts I am wanting are 308829001 (pinion assembly) and 308830001 (output shaft assembly).
  • 148 Answers
SOURCE: Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Posted on Jul 14, 2009
  • 148 Answers
SOURCE: Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Posted on Jul 16, 2009
bulldogchief
  • 388 Answers
SOURCE: I have a Ryobi 31cc string trimmer / blower /
Ok, well, go to this link: http://www.ryobitools.com/catalog/outdoor_products/trimmers
and look for the one that looks most like yours. That's about the best I can do for ya Mikey. Hope it helps.
Posted on Sep 10, 2009
Testimonial: "I have sent the question to Ryobi as suggested, thanks. I will update this group when/if they respond. mike"
  • 56 Answers
SOURCE: how do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Posted on Jul 17, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Ryobi 700r 31cc 15" Trimmer,
Hi and wel;come to FixYa, I am Kelly.
The part you need is item 9 on most parts lists:
Your problem is caused by either drive shaft failure or.. clutch failure. Most of the time the drive shaft fails before the clutch.
The manual is here:
http://www.mymowerparts.com/pdf/Ryobi_String_Trimmers_Blowers_Tillers/700r.pdf
Shaft is PN 682064 or 753-04280
Sears parts direct has the shaft as item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/Model-700R/0909/1503820/10060718/00002?blt=06&prst=0&shdMod=700R
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Ryobi-Parts/Grass-trimmer-weed-wacker-Parts/753-04280/0071/247/Model-700R/0909/1503820?keySuffixId=NA&productTypeId=x&searchModelNumber=700R&subCompDesc=Boom%20and%20trimmer&brandDesc=RYOBI&modelDesc=TRIMMER&pathTaken=partSearch&blt=11
Lower price here:
http://www.mowpart.com/p661995/Flex,-Shaft-(Rpls-682064)/product_info.html
Average price ($32.50)
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
Ryobi problems
Sorry not to have better news. The plastic housing on that trimmer is not strong enough to support the drive gears. Ryobi has discontinued that model.
I have had mine apart several times. The housing for the gear cogs is plastic and flexes. I've tried to reinforce it and added spacers between the plastic housing and the bearings that support the drive shafts in attempt to force the teeth together. But the trick only lasts for a few minutes. As soon as I start to cut with it, it stops again. It's just not worth the time, effort and frustration to continue working on it just to have it stop working again.
I finally discarded the Ryobi unit and purchased one with a metal (aluminum) housing. I think it is a Poulan Pro model from Walmart. It has worked well.
Jul 07, 2014 | Homelite Expand-It Hedge Trimmer...
Need to sharpen Ryobi hedge trimmer. How do you release blades?
A model number would be necessary. Look for a label with a model RYxxxxx.
You can see an illustrated parts listing by going to www.homelite.com. Click on the parts tab. It will send you to their parts vendor's website. Then type in your model number and you can see the parts breakdown. If your blades are rivited together, just buy a new set of blades. If your blades are bolted together, then it is possible to sharpen them.
I would still recommend to know how much new blades are. In my area, there are only 2 repair shops that sharpen hedgers, and they both charge more than $50 to do this.
Dec 22, 2010 | Ryobi Garden
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Can I get my Ryobi Hedgetrimmer blades sharpened or replaced ? Its only 2 years old and blunt already, it struggles to cut conifer and tears rather than cuts. I am not impressed.
If the blade set is bolted together, then a local repair shop should be able to sharpen them. Look for a shop that works on Echo or Stihl hedgers, as they can be sharpened. If the blade set is riveted together, then it must be replaced as a unit. You did not list the model or item number for your hedger, but try www.ereplacementparts.com or www.ordertree.com . Both sites will allow you to type in your model or item number to look up all the available parts.
Sep 08, 2010 | Ryobi 18V Hedge Trimmer
Carbon brushes needed for Ryobi Hedge Trimmer Model RHT 618, 460
check with a small engine shop near you to see if they can get these parts for you.or you might fine them at www.partstree.com.
let me know what you fine out.ok
Jul 23, 2009 | Ryobi 26CC, 22 In. Hedge Trimmer
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
207 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
