Question about Kenmore 24032\24036 Top Load Washer
No spin cycle,on any setting. seem like it wants to spin but can't
  • Kenmore Master
  • 2,699 Answers
You have a bad motor coupling,they brake all the time,remove the two screws holding down the top console,lift it up,with a screw driver remove the two metal clips and remove the lid switch harness,it's a white plastic piece in the middle between the two metal clips,now remove the frame of the washer,down the bottom you'll see the pump,with a screw driver remove the two metal clips and remove the pump,now remove the two screws and two more metal clips and remove the motor,on the back of the motor you'll see the motor coupling,it should have three plastic arms on it but they probably are broke,also on the tranny the other half of the coupling is there remove that,the part number is 285753A and it's around 19 bucks, tap on the new coupling one part on the motor shaft,the other on the tranny shaft and slide the black rubber piece on the tranny part of coupling and slide the motor onto the other half so they lock together and this is what spins the tub.if you need help with anything else let me know,also if you can let me know how you make out with your washer,good luck. the coupling brakes all the time from overloading the washer<!-- from fixya rte -->
Posted on Aug 14, 2010
  • Sal De Aug 16, 2010
    if the motor is running but the tub isn't spinning most of the time it's the motor coupling on kenmore washers,before you think it's the tranny or anything else check the coupling.it sounds like alot of work but it takes 5 to 10 minutes to get to the coupling,you have to take the pump and motor off anyway to get to the tranny anyway and way through your washer away for a 20 dollar part,check the coupling first
    i meant to write you have to take the pump and motor off anyway to get to the tranny and why throw your washer away for a 20 dollar part,check the coupling first
  • 171 Answers
Odds are that the brake/clutch mechanism is worn or bad or the transmission is gone.  my money is on the brake/clutch.  not hard to replace or too expensive to have done.
Posted on Aug 06, 2010
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Jun 30, 2009 | General Electric WSSH300G Front Load...
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
489 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
