BBC programmes do not appear in the programme index. I cannot record using video plus. I am inable to delete recordings from a reusable disc.
  • fmdixon Apr 27, 2008
    Philips dvdr 5500/5
    What do you mean by Nero
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details
so that it can help me resolving the issue is a more prompt
manner
Posted on Apr 27, 2008
  • Maanita Chadha
    Maanita Chadha Apr 27, 2008
    Try using nero and run erase disk option which should erase the existing data from the disk.
  • Maanita Chadha
    Maanita Chadha Apr 28, 2008
    Download the product from the following link.
    This is a CD/DVD burning suite
    http://www.nero.com/enu/downloads-nero7-...
Machine will not recognise a new disc when trying to copy a recording
Did the previous machine show EXACTLY the same problem, or did that machine have another issue?
Regarding this one, does the DVD drive respond well to playback discs, such as commercial release DVDs, or DVDs recorded on other machines? Does it play back CDs OK? If it passes these tests, move on to-
I suggest trying to record on different discs - such as a DVD-RAM, or on a different brand of DVD-R, or DVD-Rs from a different batch to your current ones.
If the machine succeeds here, all good and well, if it fails at this point, it seems the machine is faulty and should be returned.
Oct 09, 2014 | Panasonic DMR-EX773 DVD Player/Recorder -...
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
Can't delete recorded programmes from a DVD-RW disc. Also, the wording on the t.v. screen is not the same as shown in the Owners Manual when I use the remote controller.
U can't deleting the recording matrials in the DVD+RW disc.U only can recorded over it with new recording matrials over the old materials.What do u mean?Diffreence lanuages from the tv screen not in english or ur own country lanauge?
Oct 27, 2010 | Funai TruTech DVDVCR Dual Recorder
DRT400 TiVo 40-Hours Video Recorder: unable to delete programmes...
Do a complete CLEAR and ERASE.
This should fix the problem.
May 18, 2010 | Humax DRT400 TiVo 40-Hours Video Recorder
I WANT TO RECORD A RADIO PROGRAMME BY DOWNLOADING
Are you in the UK?
1 The easiest thing to do is to record it using a freeview box onto either a video or other recorder.
2 If that's not possible try listen again if on bbc.
3 It's difficult to record directly onto a pc without a tv capture card (and essentially doing 1 above) when you can set a timer to do it automatically.
4 if you don't have that you can connect the headphone output to the microphone input and use the Windows Sound Recorder to then recod the outpu
Nov 08, 2009 | Packard Bell Easy One Silver 2120 Notebook
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
DVD/VHS Panasonic DMR ES30V.I have a "digibox which, via the Autotune facility, has input "Free to Air" stations. However,I can only record/replay digital channels 1 - 5.others e.g BBC4...
Greetings,
channels 1-5 gets signal from the digital receiver.
and the other channels are from the autotune facility connected to the TV ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Panasonic Televison & Video
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Pioneer DVR 640 H
You may have CDs stored in the Jukebox taking up space- if so delete them.
You may have images stored in the photoviewer - again, delete...
Have you done any disc backups, and forgot to delete the backup file? Goto bottom of copy menu for disc backup, then in the disc backup menu, choose delete backup file.
Jan 04, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
