Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Canon pixma mp140 wont scan. Error code :2,114,0
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
xptareq2000
  • 1447 Answers
SOURCE: canon mp140 error code e2
paper delivery problem
Posted on Jun 25, 2009
pineworks
  • 4041 Answers
SOURCE: my canon pixma mp140 won't scan when i press the
This is onlt a try may work
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Posted on Feb 16, 2010
    SOURCE: Canon Pixma MP198 error code 2 114 0
    i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
    Posted on Apr 10, 2010
    • 284 Answers
    SOURCE: CANON MP140 PHOTO AIO P/C/S-4800X1200DPI PMFP7 All-In-One InkJet Printer: i av a pixma mp140 and the error code e4 is flashi...
    Error Code 4 is the machine detects no cartridge. You must insert both cartridges in order to use it.
    Posted on May 31, 2010
    Error 19
    Hi there-
    Below are a list of the error codes for this model.
    E16-E19 = Failed to scan head alignment sheet.
    You can find this information at http://www.usa.canon.com/cusa/home
    CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
    [Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
    is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error -
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error - USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
    Multifuncional mp140, result error 4,2 and then error 5010 solution?
    canon mp140 i get a error code 5010 any suggestions on how to fix this?
    Apr 25, 2011 | Canon Pixma MP500 All-In-One InkJet...
    Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
    The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
    Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Jan 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
    Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
    When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
    Thanks
    Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
    I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
    Halo Barbara,
    Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
    For MP150/160/170/180: Press START button (Black or Colour)
    For MP140: Hold down STOP/RESET button for about 9 seconds
    Please rate me as Fixya if this solution useful for you. Thanks
    Source:
    Canon Inkjet Printer Forum
    Nov 27, 2008 | Canon Office Equipment & Supplies
    Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
    906 people viewed this question
    old marine
    old marine
