Question about Kitchen Ranges
Where is the fuse for a Maytag Microwave model # mmv4205aaw...the entire microwave just shut down
  • 4,323 Answers
Hi
There are three fuses inside the microwave. Please check part #31(PS2052772-- Fuse 20A) in the following diagram--
Please check part# 21 (PS2005451-- Fuse) in the following diagram--
Also check part# 34( PS2174090) in this---
Hope this helps..
Daniel
Posted on Aug 07, 2010
Maytag microwave overheated and shut off - Model #MMV5165BA
That is not good, the magnetron has gone, or the thermal fuse has failed, "protects the magnetron from overheating" There is a possibility the keypad control board was a affected.
Apr 07, 2012 | Maytag MMV5100A Microwave Oven
Hi. I accidentally ran my Maytag MMV4205AAW on high power for about 15 minutes with nothing in it. After I stopped it, it wouldn't come back on. No surface light - nothing. My circuit breakers are...
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
Jan 14, 2018 | Maytag MMV4205 Microwave Oven
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
Mmv4205aaw turns off
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 05, 2010 | Maytag Appliances Over-the-Range Microwave...
HOW TO REPAIR MAYTAG MMV4205AAW MICROWAVE NOISY FAN
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Jan 11, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag Microwave Oven (MMV4205AAW) won't power on.
You will need to replace the 20 amp. ceramic fuse inside the unit. This is real easy and the fuse only cost around $10.00 You will find a break down of your unit at www.partselect.com just enter your model number and a break down will come up. Your part number is PS2052772. You can also locate where the part goes. Good luck.
Oct 15, 2009 | Maytag MMV4205 Microwave Oven
Maytag MMV4205BAS OTR microwave does not vent internal steam and the microwave shuts off. It takes about 15 minutes to reset and power back up. What part is bad?
I have this same microwave, and I'm having trouble with it shutting off. It use to go back on, but now it doesn't work at all. I tried replacing the two fuses under the panel, but that wasn't the problem.
After some research and calling vendors, I believe the issue is most likely due to a failure of the magnetron tube which supplies the microwaves. Take it to a repair professional to get a cost estimate on fixing.
This model of Maytag seems to have BIG problems! It's either the tube is out, the turner doesn't work, or it just goes dead. Usually it's after 2-4 years of service. Poor quality... Maytag lost a lot of clients with this product!
Apr 12, 2009 | Maytag MMV4205 Microwave Oven
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Function of thermostat-switch
We have *critical* safety, disassembly, and troubleshooting info at our
site, and our link is at our listing here on FixYa:
http://tinyurl.com/yzjozk
Once you\'ve looked those over, here are some links on part testing:
http://www.microtechfactoryservice.com/cap_test.html http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Maytag MMV4205 Microwave Oven
Kitchen Ranges Logo
472 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
