Question about Car Audio & Video
Bmw 318i se auto clock reset problem? - Car Audio & Video
    Problem Solver:
  • 12 Answers
A little more information would be nice but im going to make a guess
you installed a new deck in the car, now every time you turn the car off the clock resets?
if thats correct.. the deck will have 2 power inputs, one that turns the radio off when it does not have a power signal, the other that should have a constant voltage to maintain the stereo memory, now if I'm correct you have either the 2 wired opposite to how they should be or both wired to something like the ignition wire, and it is acting like the battery has been removed every time you turn off the car, which means you need to check your stereo wiring.
if this is incorrect please leave some more info telling everyone when the clock is automatically reseting.
Posted on Aug 06, 2010
I just bought my 2007 bmw 318i, and I just realise
Yes. It's in the speedometer area now. Press the BC button on the steering column to rotate thru the info.
Oct 21, 2014 | 2007 BMW 318i Touring
Will a 1991 automatic BMW 318I driveshaft fit in a 1991 manual BMW 318I R
no the auto is shorter because the transmission is longer
Mar 24, 2013 | BMW 318 Cars & Trucks
I need to reset the service interval indicator for a 318i 2008 plate
3 choices: A) Dealer B) Specialty Shop OR C)Buy the rest tool from Bav.Auto.com
Many a BMW owner owns the reset tool, especially if you do a bunch of your own maintenance.
Feb 26, 2011 | 2008 BMW 3 Series
How do you set the clock on a 1999 BMW 318i please.... have tried every which-way
If you've tried every which way.....the clock is broken. Included in everywhich-way would be the correct way so that didn't work? Cell phone has a clock on it.
Jun 12, 2010 | 1999 BMW 3 Series
Car shuttering when started,like its not tune,rev up and down.
idle control valve, remove top intake manifold to get to it. replace icv and two hoses going to it. anything else plastic or rubber that breaks along the way...replace that stuff too. plan on 3 trips. to the auto parts store the bmw dealer and hardware store.
Jun 07, 2010 | 2000 BMW 3 Series
Just got a 1998 bmw e46 318i se auto. Auto warning light was coming on frequent, and going into protection mode. Took to bmw dealer, who run tests, and filled with gear box fluid. Problem still occurs, but...
if the transmission was low on fluid you may have worn some parts,take this to a shop that specializes in BMW transmissions,this is not for the local transmission guy,special tools needed to test the transmission,may have to be re-programed
Nov 11, 2009 | 1997 BMW 318
I would like to know how to reset the oil change indicator on a 1994 BMW 318i
Switch on ignition.
Earth terminal 7 (I've no pic sorry) and hold for 3 seconds.
Switch ignition off
That should do it
Apr 28, 2009 | BMW 318 Cars & Trucks
BMW 318i SE Airbag light
something in the airbag system is at fault. it could be the airbag(s) itself or any of the sensors that detect a crash to deploy the airbag. i would really take it into BMW and have it checked & repaired. the airbag(s) will not deploy with this light on so your safety is at risk if you are ever in an accident..
Mar 06, 2009 | 1997 BMW 318
Dashboard light and instruments not working
bulbs behind the gauge cluster most likely need to be replaced....
Jan 04, 2009 | 1991 BMW 3 Series
this problem is most commonly caused by the rotating contact under the steering wheel (also called the clock-spring contact), it has developed and open circuit, the airbag control/diagnostic monitor senses this and disables the airbag system
Dec 09, 2008 | 1999 BMW 318 ti
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
