Bosch Maxx Washing Machine My fabric softener is not being taken into the wash. Water is going into the compartment. Then when I do my next wash if I put some more softener in, it fills up to the max level and immediately drains away, so no good as you want it at the end of the wash.
  • bobbiescott Apr 28, 2008
    Hi there is no hose and levers etc, water comes in through holes above the drawer. I have cleaned everything I can, and the softener has gone into the wash but that compartment is full of water, so when I add the softener to the next wash it will empty immediately and not when it should. Any other ideas?
    Bosch MAXX WFL 2260 hope this helps.
  • Washing Mach... Master
  • 19,396 Answers
Check the hose at the back of the softener drawer, check that they are not obstructed, check also that the lever closing and opening the holes for softener and detergent is moving regularly
Posted on Apr 27, 2008
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 28, 2008
    Make sure the power is turned off. Take the top off the machine two
    screws at the back need undoing then remove centre bar which holds the
    drum up and supports drum. Then remove the pipes and the white box
    which the water comes into it is all clipped together and comes undone.
    The box splits apart so you can clean the black sludge out. To stop
    this happening again I cut off part of the white holed section where
    the water comes in about 1cm and then clipped it all back together and
    reassembled it all. It took me about 45 minutes to do this but it was
    worth it. I did this about 2 years ago and I've never had trouble since
    as the hole for the water to come through into the fabric dispenser
    drawer is now much bigger.
  • Maanita Chadha
    These links may help you:
    http://www.howtomendit.com/answers.php?i...
  • Maanita Chadha
    http://www.signvideo.com/conv-v-to-d.htm
I've a Bosch avantixx washing machine and it won't empty the fabric softener unit. It has water left in or some softner. I've taken the tray out and cleaned it.
The softener unit is flushed between wash cycles to prevent clogging. What you are describing is normal operation.
Jul 12, 2016 | Bosch Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
My Bosch washing machine doesn't add the softener from its compartment
The first thing you should do is check the compartment from the fabric softener. If something is blocking the exit of the softener, the machine will not add it.
If you checked the exit or the holes in the valve of the fabric softener compartment and nothing seems to be stuck there, there could be a problem with your washer's timer. Check the timer and get a replacement for it.
source: http://www.washingmachineadvisor.com
Jul 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The Softener is not going through.
you need to take the soapbox out and clean thoroughly. Pull the soapbox out to the point where you get resistance and the you will see a tab you press to release it fully. Do not force the soapbox out. Take it to the sink and clean with hot water. Softener can be like jello when it drys and will block the release.
May 24, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Water remains in fabric softner compartment
Is the softener entering the machine; that is at the appropriate time? You can take a peep at this time, if possible. If it is water it is okay; this is just the remaining water. The softener is dissolved with water and flushed into the machine.
Dec 05, 2007 | Bosch WFMC 3200 Front Load Washer
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
