Question about Troy Garden
Son ran over some chain with my Troybilt mower with the HONDA 160CC OHC engine. Since then, the mower cuts off when it gets into higher grass. Problem getting worse , almost like something is loose?
  • 252 Answers
Check that the blade disc or carrier is tight and the woodruff key on the pto shaft has not shawn / sheared
check the flywheel key under the starter cup nut
could be sheard and is out of time or is moving when unit starts and stops
a shawn key will not stop it from sparking just wont spark @ correct time , check that pto is not bent
might pay to check camshaft timming as well and check timming belt
here is web site for parts breakdown
http://www.honda-engines-eu.com/en/welcome.html
go to service, spare parts , then select gcv160 from list
then hit search
a engine list will come up
cheers hope it helps
Posted on Aug 13, 2010
Troy bilt lawn mower
This is not a common problem. The bolts are at fault. You can replace them and it will work but make sure they are the right bolts and you put them in tight.
Jul 13, 2013 | Garden
Honda pressure washer
disconnect the engine from the pump and see which unit is not turning for starters. I suspect the pump because it has water left in the pistons and rust will set in on the flap valves .You may have to pull the pump down to repair this problem
May 17, 2013 | Horizontal OHC Engine 160cc, GC Series,...
Just bought this mower honda hush arena 21 " push mower and it throws clippings all over the deck, why? Looks like its coming from the side outlet
See if the side outlet needs a plug underneath to keep the grass inside the deck to be mulched. A lot of mowers have these plugs but this one might have not been installed.
Jan 19, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to fix Honda HR215 mower from skipping grass
check the belt tension on the deck
Apr 22, 2012 | Garden
I have a troy bilt riding mower. I put a new battery in it last summer. This yr., my son left the key in on positon when he got done cutting the grass. Naturally it killed the battery, I jump started the...
It may not be charging due to a bad connection to the battery or to the generator on the engine. The generator on the engine may be going or has gone bad.
I hope this helps.
Jul 27, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Runs but cuts out when transmission is engaged
Check the deadman switch on the seat, I had the same problem with my John Deere and that's what it was.
Apr 22, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
212 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
