Question about Westinghouse W33001 30 in. HD-Ready LCD Television
I have an issue with westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset? Also I took set apart and found that where the power supply connects to main board is burnt. I now believe that Main Unit Board and Power supply needs to be replaced. I can find Main Unit on line for purchase but can't find power supplay and connector to main board. Where can I find these parts?
  • 11,361 Answers
  • 1 more comment
  • John Talley Aug 08, 2010
    Thanks for the power supply information. Now I need the connector from pwr supply to Main board connector for this model TV. Does anyone know the part number, name of part so on?
  • Bud Martin
    Bud Martin Aug 08, 2010
    The power connector is not at the main board when you purchase the new main board? The four-pin connector is a little hard to come by, you can try Mouser under DC power connector.
  • scooter101 Apr 06, 2011
    I have the same issue. jotalley54, did your issues get solved?
After defrosting, red alarm light on, green power light off. Westinghouse Silhouette FR393Q freezer.
Alarm means that the unit is overtemp for a freezer. Your breaker was likely overloaded if the same issue didn't follow the machine to the next outlet... If the alarm stays on when the unit is clearly freezing, you have some type of control problem. That model number is incomplete/incorrect.
May 25, 2016 | Refrigerators
My magnavox hdtv won't turn on no green or red light on the power butten no power at all
Start with the obvious. Is your TV plugged in? If it is on a power strip, does the strip need reset? If all is normal there, then unplug the set and take the back off. Check your fuse to see if it is blown.
May 17, 2012 | Televison & Video
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I am powering up and the flat screan turns on and
More likely to be bad caps (bulging top/seal) in the power supply, which when they failed, they may have taken out the inverter fuse on the transistors in the inverter circuits also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset?
The green light means the 5v standby circuit is working, yes it can be a fuse for the main power supply section that gets the control signal from the main board to turn on, so it can be the main power supply or the main control board.
Nov 03, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
No power
capacitors on the power pack are blown or bad need to replace these, this will require soldering skills.
Apr 07, 2009 | Runco PlasmaWall PL-61CX 61 in. Television
Ford 6006e rds eon cd radio - won't switch on
remove the head unit from the dash, unplug the main connector from the rear and then plug back in. the unit seems to reset itself and asks you for the security code, should work afterwards. must be common fault as ford dealer new exactly what to do when i took mine in.
Apr 01, 2009 | Car Audio & Video
WESTINGHOUSE MODEL W 33001 GREEN LIGHT NO PICTURE OR SOUND
It's posible your TV when into protection mode to prevent further parts from being damaged. This normally happens when a single parts goes bad inside your TV.
You may have to take it to a repair shop.
Feb 09, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Aug 25, 2008 | Westinghouse W33001 30 in. HD-Ready LCD...
Video problems with my westinghouse LTV 32 W 3 HD
This seems to be associated with the overheating of some component. On my set I need to check that the backlight is set to a low level. On reset it automatically adjusts to a level above maximum and the green screen will appear in a few minutes. I took the back off and that helped some.
Nov 27, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
463 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
