Question about Cameras
When there is a bright sun I cannot see anything in the digitail viewfinder; the camera has no optical viewfinder.Help!
  • 2 more comments
  • jijima Apr 27, 2008
    Camera is an 'ADVENT MP71', which has no settings.
  • jijima Apr 28, 2008
    Thanks but it does not help I have read manual.
    The camera is an ADVENT MP71.
    I have read the manual but it does not help!
    Photograps taken with a white screen are fine, except I am not sure what I have taken.
    President:
  • 2,712 Answers
1. Do you get the same problem in regular lighting as well? If you do, it could indicate an LCD chip level problem, and if your camera is under warranty, I recommend you get it replaced.
2. You could try using a "viewing hood" to block out the sunlight,as shown in the pic below:
You can purchase that online from HERE. I think it cost about $15-20
3.You could even try anti-reflective coating on the lens, although I do recommend the "hood" from point 2 above.
4. If you do not wish to spend $15-20 on the hood, you can try an inexpensive alternative. Take a piece of cardboard and cut it in such a way that one end fits exactly around the digital viewfinder and gradually tapering in to a narrower viewing area. About 2inches depth should be enough. Tape the edges, and voila! you have a hood. Should warn you that this may be a bit of an inconvenience as you will have to hold the hood in one hand and click with the other. But as long as it solves the issue...;)
Unfortunately, there is no other solution, as your camera does not have any other settings. Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 28, 2008
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    The pic below will give you a rough idea on how you should cut the cardboard to give you the "tapering" effect on the board. Well, it could just be a case of trial and error, till you get the correct shape.
    Genius:
  • 3,422 Answers
Well there is actually no solution to fix this problem all you can do is change your camera.Since this camera has no settings also which can be changed.You can CLICK HERE to check out the forum and the reviews for the best camera with an optical view..
Goodluck,
Please don't forget to rate the solution
    President:
  • 1,944 Answers
Unfortunately, that is the disadvantage of having only a view finder on an LCD screen. It appears that your camera is not using a transflective screen. What you need to do is get some shade onto the screen so the screen can be seen.
  • 13,433 Answers
The light is too bright for your camera or you need to adjust the cameras settings, yes brand and model of your camera would be helpfull.
Posted on Apr 27, 2008
  • 2 more comments
  • Ekse Apr 27, 2008
    So the digital view is all white then? basicly the light is too much for the camera.
    What happens to the pictures if you take one even thought you dont see anything? are they all white?
    If there are no settings in the camera, and I don't know, I cant find anything about advent cameras. Just some basic info but noting settings vice / or manual. If you have the manual I recommend you take a look at it.
    Then the light is too much for the camera to handle I supose theres noting I can do or suggest other than going thought the manual if you have it and look for exposure settings. If theres no settings then I supose theres noting we can do.
    Maybe some other expert has more info on this.
  • Ekse Apr 27, 2008
  • Ekse Apr 28, 2008
    Then there is noting you can do, the light is too much for the sensor.
  • Ekse Apr 28, 2008
    You can try useing sun glasses on over the camera while takeing a picture. then take them off after you have locked on to your target and shoot. heheh
    Genius:
  • 1,447 Answers
Whats the exact model and brand of your camera?
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 27, 2008
    Hi you will learn something on this site regarding the camera setting.
    Click here CAMERA
    Hope this helps
Why can't I see lcd screen properly in the sun
When I can not see LCD screen when sun shines on it I use viewfinder , I think it tells you in the user Instruction manual if sun is so bright you can not see LCD use viewfinder .
May 16, 2014 | Konica Minolta DiMAGE Cameras
Camera problem I have a Kodak Easyshare c190 camera and i went to the beach and you can not see ANYTHING thru the viewfinder. I tried desperately to turn every way and covering all around it but just could...
Viewing the screen in bright sun is a problem for 99% of point and shoot cameras. 1% still have an optical viewfinder you can look through to frame the picture. Also, looking at the screen with polarized sun glasses makes the problem worse. There's no solution except to upgrade to a DSLR camera.
Apr 15, 2011 | Kodak EasyShare C190 Digital Camera
When I am outside, I can not see anything on the screen to take a picture because of the glare. I have tried covering the camera but still cannot see.
This is normal. If the sun is very bright, it overpowers the lcd screen. In this case, I normally switch to the viewfinder.
Mar 15, 2011 | Vivitar ViviCam 5024 Digital Camera
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Mar 01, 2011 | Fuji FinePix S5000 Digital Camera
I want to take pictures outside but i cant see it on the screen what do i do
There's nothing you can do. When they took away the viewfinder, it became almost impossible to shoot outside in bright sun. Some high-end cameras automatically brighten the screen but even that isn't much help.
Feb 20, 2011 | Vivitar V5024 Digital Camera
Low Lite LCD Use
The LCD is completely WYSIWYG and if you can't see anything through the LCD then the picture you take will be black too. If you are outside and open the shutter really wide you will see the LCD go white as the light overpowers the exposure. The best thing to do is to increase the ambient light in the area by turning on every light. You will still use the flash for the picture but you need to get more light on the scene to see through the LCD. For what it is worth, an optical viewfinder probably wouldn't do any better job in those situations.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
LCD in the sunlight
The 2.5" LCD on both cameras uses a special back lighting system to help cut down on sun glare.
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
LCD in the sunlight
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
LCD working in the sunlight
Sep 01, 2005 | Panasonic Palmcam PV-DC2090 Digital Camera
How does the LCD work in the sunlight?
Sep 01, 2005 | Panasonic Palmcam PV-DC1080 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
