Question about Pride Jazzy 1103 Ultra Standard Power Chair
How do I increase the speed . It seems that it ran faster on the straight and now I don't feel with all the bars lit that the speed is like it used to be. Please tell me what I can do to make sure I will have the proper speed per the bar spped indicator. Thanks from Lynda
    Novelist:
    Champion:
  • 232 Answers
How long have you noticed the decrease in speed? Are you charging the batteries regularly? Have you checked your air pressure in your drive tires?
If the batteries are getting old or the power chair has been stored for a while, the batteries may not be taking a full charge. If your speed indicator is showing full like always but the power chair is not responding like it used to, it may be a battery issue.
As you operate the power chair, listen for noise and pay attention to see if there is any vibration, this may indicate a mechanical problem that is causing power drain.
If not, your power chair may still be within normal parameters, just not "new out of the box" anymore. Make sure that you decrease your speed when going up inclines to avoid excess wear on the motors.
Posted on Oct 20, 2010
Tip
How to increase speed in non-gear bicycle
While riding your bicycle,you might find it hard to accelerate. You may feel like pedalling at the same rhythm. At these times,it is good to raise your back a few inches from the seat and pedal. This reduces the gravitational concentration near your seat and the pressure from the weight of your body on pedals will increase. Now you can pedal faster with ease.
Note:Since raising from seat and pedalling cycle makes way for more energy burn,you might get tired soon. Alternate this method with usual cycling to go faster in cycle.
Warning: Chances are your leg might slip pedal and you may hit the bar or seat. Remain careful while pedalling as i said. Avoid this method when your feet is slippery.
on Aug 08, 2011 | Cycling
Grinding when shifting from 2nd to 3rd
RPM's up + car speed not increasing = slipping clutch disc, yes, sounds like bad clutch.
Aug 16, 2013 | 2006 Toyota Corolla
I do not understand about torque on my new makita 18v lithium-ion battery drill. When I use it through drywall then into wood or straight wood into wood it seems to stall when I am almost done. Is this to...
Hi Kathy,
Welcome to fixya!
You adjust the torque by increasing the setting on the dial behind the chuck. It will feel to you as if you increased the power when you drill.
Don't set it higher than you need it. Just increase the setting until you're happy with the way it's working.
Good luck
Please place a vote and keep me working here...
Thanks,
Handie Andie
Aug 14, 2011 | Makita Garden
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
I need to know if the CPU speed can be increased to 1GHz or over and that I have put in 2 memory modules of 128MB onto it but only 128MB appears on the System Properties. Irvin.
You are confusing 2 things, CPU speed and Memory or Ram speed.
To keep things straight forward, cpu speed can only be increased by replacing it with a faster cpu.
Ram, as you can see, can be increased by adding faster ram modules.
Go to either of these websites:-
http://www.orcalogic.co.uk/asp/default.asp
http://www.crucial.com/uk/
Enter *********** board details or request they scan your computer. Check all the information offered, they will tell you what type and how much ram your motherboard can use.
If you can't increase your ram speed to more that 1Gb, I would suggest it time to invest in a new motherboard/PC rather than spending more on RAM.
There can be a whole load of reason why your second stick of ram doesn't work.
1) it could be broken.
2) It could be the wrong type.
3) You may need to update your Bios to accommodate it. Though this is very unusual.
Jul 28, 2010 | Intel Motherboard
Minn Kota Edge 12 volt 40lb. thrust. Problem with steering straight ahead. If steering to the left or right, if correcting to go straight ahead, the motor goes beyond center as if there is slack in the...
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 03, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
145 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
