Question about GE Profile JSP47 Electric Single Oven
How do I remove glass top to replace it - GE Profile JSP47 Electric Single Oven
  • bongo416 Aug 06, 2010
    These instructions would only work if the control panel was in back but the control panel on this stove is in front and it looks like it has to come off first.
    Genius:
  • 1,478 Answers
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged before attempting anything.
Take care
Posted on Aug 06, 2010
  • 881 Answers
You can lift it up by removing 2 to 3 screws found when you open the oven door, under the front edge.
WARNING: Make sure to unplug all electrical wirings first before the repair.
    My stove is a JCS968 that I can not find in your list but this one looks the same. I can not see that your instructions will work as the control panel is in front and I can not see where screws would go in to the top frame.
  • kid_ant
    kid_ant Aug 06, 2010
    open the oven door and you will see the screw underneath glass top.
How do you clean the oven door between the glass.
with great difficulty!! door has to be removed from the oven then on a flat surface remove the screws around the edges then lift the top half off . clean glass dry really well and replace it in the shell . replace top half of door and retighten the screws . replace on oven .
Mar 15, 2017 | Ovens
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Aug 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Jan 25, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
GE Profile JSP47 Electric Single Oven Logo
65 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
