Question about Craftsman 42" Briggs Stratton 20 hp Gas Powered Riding Lawn Tractor
The starter does not seem to get enough power to start mower, sometimes it turns motor over and sometimes it turns real slow and wont fire. I have charged bat. and cleaned all conections still no luck. any idea's would be great. I have a new bat. to
    Novelist:
  • 146 Answers
If the battery and cables are good, then it's likely either the solenoid or starter motor is failing; doesn't matter which because you generally replace them together as an assembly. But before you shell out $80-$100 for a new starter, be sure you've checked not just the connections at the battery end, but also the other end of the heavy cables going to the battery. The heavy red cable goes from battery to solenoid - make sure the nut is tight that holds the cable onto the solenoid. Be sure to disconnect the battery negative lead before you put a wrench on that solenoid terminal - shorting it to the chassis would cause a disaster. Also check the heavy black cable that goes from battery negative to the chassis - it is common for rust to occur at the chassis connection. If so, just take off the cable lug, clean the chassis and lug surfaces with a wire brush or sandpaper, and retighten the bolt. Good luck!
Posted on Aug 07, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
422707 model
Battery or starter not giveing enough power.
Jul 29, 2014 | Garden
Starte spins when trying to start riding mower.
You may need a starter bendix. The slow cranking may be unrelated and due to a weak solenoid.
Jul 16, 2014 | Cub Cadet Garden
Riding mower wont fire, new starter installed
We need more information to help you. Is it that it won't turn over with the starter or that it won't fire to start when the motor is cranking over with the starter ?
Jun 18, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
My husqvarna zero turn rz4621 starter is getting enough voltage, but isn't putting out enough to start my briggs and straton motor. have checked with meter starter and silinoid, have had battery checked...
it maybe that the battery is getting old or is not the right rating if the AH Start rate is too low it will not have enough power to turn the starter motor. ensure the battery you use has enough Starting Amps rated. if this is not the issue have the starter motor checked out.
I hope this was useful.
Oct 31, 2013 | Husqvarna Mower Rz4621 Zero Turn
Toro wheel horse 15-44hxl wont start
What motor do you have. Briggs & Stratton motors are notorious for the valves getting out of adjustment. When this happens they frequently develop a tight spot that is very hard for the small batteries and starters to push past. This often results in this sort of condition. Sometimes you can help it by jumping it off another battery to boost the cranking power, however it's best to get the valves into proper adjustment. If you have good connections and have ensure that your starter is getting enough power, make sure you have spark by pulling your plug (the motor should crank well even if valves are out for a spark test, it shouldn't hurt anything doing it). If you have spark and all else is well, check the valves. If they are right, you may need to re-clean the carb if you still can't get it to fire, focus on making sure the idle jet is clean. Also make sure it hasn't fallen out. These jets are tiny and can EASILY fall out of the carb and disappear unnoticed when you remove the fuel bowl to clean it. (speaking from painful, embarrassing experience)
May 07, 2013 | Garden
Will not fire when switch is turned to start
Will not crank or will not fire? Most modern lawn mowers only use the battery for lights and turning the starter. If your battery wont turn the starter take it out and have it load tested at the parts store. You may find the battery doesnt have enough amperage to run the starter motor.
Jan 08, 2013 | Garden
40hp evinrude wont turn over with starter
starter or battery not sufficient capacity to crank the engine fast enough under compression
Jan 01, 2018 | Boating
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" Briggs Stratton 20 hp Gas Powered Riding Lawn Tractor Logo
676 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
